> How to remove sparkplug?
post Jul 12, 2005 - 6:57 PM
roswell81
Joined Jul 12, '05
smile.gif Hi, all! I am experiencing a problem when chaging a particular plug on my 5s-fe... Ok, when we stand in front of the engine bay facing the engine its the plug on my outer most right... yeah the one nearest the distributer... I have problems getting it out with the regular size of the tool that was used on the rest of the 3 plugs.. What would be the problem??
Hope, someone would be a ble to enlighten me on this problem... & how to remove it of cos.
Replies (1 - 7)
post Jul 12, 2005 - 7:17 PM
I'm assuming your using a spark plug socket? Try to get a light in there and see if you stripped it.
post Jul 12, 2005 - 10:40 PM
CelicaSTX02
Joined Sep 24, '02
From North Carolina
There are sparkplug sockets with the rubber inside the socket that helps get it out real easy, have you tried using one of those??
post Jul 13, 2005 - 1:38 PM
roswell81
Joined Jul 12, '05
QUOTE(Supersprynt @ Jul 12, 2005 - 7:17 PM)
[right][snapback]311697[/snapback][/right]
Hi thanks for the reply. I got a light in wat i saw was like a reall shallow worn out plus as if it has never been changed out b4... surrounding the plug seems like there is a rubbery outer rim on it. I wonder whether if the plug was there ever since the car was born???
post Jul 13, 2005 - 1:39 PM
roswell81
Joined Jul 12, '05
QUOTE(CelicaSTX02 @ Jul 12, 2005 - 10:40 PM)
[right][snapback]311807[/snapback][/right]
Not exactly hehe.
post Jul 13, 2005 - 3:22 PM
Go to the autoparts store or if you have a decent ratchet set it'll have it there and use a spark plug socket. That way the plug will stay in teh socket and let you pull it out.
post Jul 14, 2005 - 12:30 AM
MonsterBOX
Joined Jan 8, '05
From Alabama
after its unscrewed take out the wrench and put the plug wire into the hole until it locks down onto the plug, then pull the wire out and its on the wire
post Jul 14, 2005 - 9:08 AM
toyotatech
Joined Jun 14, '05
From colorado
QUOTE(roswell81 @ Jul 13, 2005 - 1:38 PM)
[right][snapback]311992[/snapback][/right]
the rubbery outer rim you are talking about is probably part of the spark plug wire! get some long needl nose pliers and get it out of there and then you should not have any problems with the plug. oh and the spark plug socket is a 5/8
Lo-Fi Version Time is now: June 12th, 2026 - 10:46 PM
