Jul 13, 2005 - 12:43 PM
Enthusiast ![]() ![]() ![]() Joined Oct 10, '04 From New Jersey Currently Offline Reputation: 0 (0%) |
i was letting my car warm up one day a noticed that the RPMS were acting weird, i reved the engine and they went up stoped, came down went up, got stuck and fell back to 1K, then died. i relized my o2 sensor was blown and my plugs were shot, so i replaced the plugs and theirs still no spark. WTF is wrong with my car!?!?!?!!?
Jul 13, 2005 - 12:54 PM
QUOTE(StreetRacing10PSI @ Jul 13, 2005 - 10:43 AM) i was letting my car warm up one day a noticed that the RPMS were acting weird, i reved the engine and they went up stoped, came down went up, got stuck and fell back to 1K, then died. i relized my o2 sensor was blown and my plugs were shot, so i replaced the plugs and theirs still no spark. WTF is wrong with my car!?!?!?!!? [right][snapback]311979[/snapback][/right] so did you pull one of the plugs and cranked the motor and didnt see any spark check them all then the distributor like the cap and rotor -------------------- yea your 3sgte is cool but ill stick to my 7agte
Jul 13, 2005 - 1:50 PM
do you have the right heat range plugs as well?
but yea check wires cap and rotor and double check your connections |
Jul 13, 2005 - 4:32 PM
i pulled the plug and their was no spark, and i took apart the distributor cap and their were all these lil metal shavings in their.
Jul 13, 2005 - 11:58 PM
time for a new cap/rotor/button set!
Jul 14, 2005 - 10:02 AM
QUOTE(StreetRacing10PSI @ Jul 13, 2005 - 2:32 PM) i pulled the plug and their was no spark, and i took apart the distributor cap and their were all these lil metal shavings in their. [right][snapback]312056[/snapback][/right] metal shavings can you see where they came from? you might need a hole new distributor start with replacing the cap and rotor and go from there -------------------- yea your 3sgte is cool but ill stick to my 7agte
Jul 14, 2005 - 8:40 PM
ends up that when i replaced my coil pack a wire was in the way of the distributor which caused it to snap. its up and running now tho
| Lo-Fi Version | Time is now: June 12th, 2026 - 3:00 AM |
