> how do i lessen my oil pressure?, too much pressure
post Aug 22, 2005 - 10:15 PM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
I had too much pressure on my crank case. would an oil resivoir help any?
-97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre
(GOT LIFT?)
Replies (1 - 8)
post Aug 22, 2005 - 10:22 PM
what weight oil are you using ?
the lower the weight/viscosity the lower the pressure. 5w-30 is the best way to go.
what is your pressure ?
post Aug 22, 2005 - 10:50 PM
I wouldnt use that thin of an oil on a 100,000+ engine.
post Aug 24, 2005 - 1:41 AM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
i'm using 10w30 and all my seals are broken on the case, i dont know what pressure. It was with a turbo.
-97 Celica ST
(GOT LIFT?)
post Aug 24, 2005 - 9:48 AM
nik
Joined Sep 30, '02
what psi were you boost on what size of turbo?
post Aug 26, 2005 - 10:42 PM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
7psi and t-26 i think
-97 Celica ST
(GOT LIFT?)
post Aug 26, 2005 - 11:36 PM
use an oil pressure regulator....you don't wanna see more then 55psi at the turbo
post Aug 27, 2005 - 2:07 AM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
any info on it? any suggestions on which to buy, where it goes, who has one?
-97 Celica ST
(GOT LIFT?)
post Aug 27, 2005 - 10:32 AM
www.atpturbo.com has some in-line restrictors for the turbos, i dont know about the sizes and stuff for you guys tho.
going off dustins(bat) pressure, i would think that you prolly would need some kind of restrictor in there.
::Edit::
somthing like this :
oil restrictor
This post has been edited by presure2: Aug 27, 2005 - 10:35 AM
Lo-Fi Version Time is now: September 1st, 2026 - 3:21 PM
