> rear brakes? not working right
post Aug 26, 2005 - 8:48 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
I replaced my rear brakes and now my hand brake dosnt work also the rear brake dosnt seem to be working right. I have repolaced rear drums before without a problem but am more faimliar with disc. Do you i have to tighten the one tensioner bolt until the drum and barley fit on or what?
Please help.. thanks
Doug
Replies (1 - 4)
post Aug 27, 2005 - 10:21 AM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
do you have drums? Well you might have to tighetn the adjuster screw thats at the bottom of the brakes that will spread the brakes apart.
post Aug 27, 2005 - 2:38 PM
crazycel18
Joined Jun 22, '04
From portland OR
i just did my drums you need to run the adjuster out a little ways and get them petty close to touching (to where you can stilll slide the drum on ) and then before you drive pump the brakes and they should adjust themselves out the rest of the way being as they are self adjusting
There Ain't No Party Like A Celica Party
A Day Without Celica is Like a Day Without Sunshine.
post Aug 28, 2005 - 5:52 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
The drums are self-adjusting up top, at the wheel cylinder. The bolt on the bottom has to be manually adjusted, somewhat, as crazycel18 noted. You'll want to drive it a bit and make a series of forward and reverse stops to get them to completely adjust.
The parking brake should also adjust itself if you work it up and down a few times. If it still stays loose, pull the centre console and adjust the brake lever. You'll see two nuts on a single rod at the base of the handle. Hold the bottom nut and loosen the top one. The bottom nut adjusts the position of the handbrake handle, while the top nut locks the adjusting nut into position. You should have 4-7 clicks when applying moderate force to lock the brakes.
post Aug 28, 2005 - 6:58 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
I think i just need to self adjust it a bit, cause i put them on, with the bolt completely back. as in the lowist setting so the drum would fit on. I think im gunna pull them off tomorrow and adjust top the point it barley goes on. Cause it seems i can pull the brake all the way and it somewhat tightens and i then have rear brakes.. I just hate drums.. but dont like my car enough to bother swaper rear disc's.
Lo-Fi Version Time is now: August 25th, 2026 - 12:20 PM
