> Megasquirt to be installed, How do I fool my ECU?
post Sep 2, 2005 - 3:05 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
For those of you who have a piggy back unit. How did you fool your ECU?
I want to know cause im about to install megasquirt and I want to know where my injector wires that connect the ECU would go? confused.gif confused.gif confused.gif confused.gif confused.gif confused.gif
Replies (1 - 13)
post Sep 2, 2005 - 3:18 PM
Just out of curiosity, why don't you just use the Megasquirt for fuel and spark and remove the factory ECU altogether?
post Sep 2, 2005 - 4:20 PM
dans_st
Joined May 24, '03
From Andrews TX
I also was looking at using the Megasquirt on my car my question is can you use your factory harness?
If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
post Sep 2, 2005 - 9:16 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
The thing is coomer, I really dont want to add edis to my car right now, because I would have to add the trigger disc and that seems to be more work than just the wires itself. The other thing is I'm not to sure if I can even program the unit let alone all the spark tables. If they at least have made a guide for an idiot for the 4age then I would attempt to go at it.
post Sep 4, 2005 - 1:25 PM
Snarfer
Joined Dec 2, '03
From Virginia
I'm confused about what you are asking? I would be pretty weary of installing the megasquirt and allowing the ecu to handle spark. It might advance/retard at stupid times and open/close the egr if you still have that at stupid times. As far as wiring the injectors did you get a relay board? Megasquirt isn't sequential so you will end up wiring all 4 injectors to bank 1 and they fire at the same time. Most of the time you only use bank 2 if you have 6+ cylinders or water sprayers.
post Sep 4, 2005 - 4:03 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
That's not how megasquirt works. If you're looking for a piggyback... mesgasquirt is not for you. If you wanna do something easy... megasquirt is not for you. Megasquirt controls injector pulses and fueling... it completely overrides the ECU's fuel control... so there is no "piggyback" so to speak. Megasquirt basically detaches the injectors from the stock computer.
post Sep 4, 2005 - 4:29 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
If you haven't already, check out www.msefi.com Look up "Megasquirt n' Spark", that's the setup you want. You can set the MS up to control your stock distributor system, basically.
The current project in my shop is an '89 MR2 with a 4AGE 20v Silvertop and MS n' EDIS, I'll post the updates for you all if you want.
-Doc
This post has been edited by Dr_Tweak: Sep 4, 2005 - 4:30 PM
Click here to see my swaps
drtweak@phoenixtuning.com
post Sep 4, 2005 - 9:55 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
QUOTE(Snarfer @ Sep 4, 2005 - 1:25 PM)
[right][snapback]331034[/snapback][/right]
A relay board? I see that most people have it, but do I really need the relay board? Isn't it just for a saftey precaution for the MS unit from frying out?
post Sep 4, 2005 - 10:25 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(soulshadow @ Sep 4, 2005 - 6:55 PM)
[right][snapback]331156[/snapback][/right]
no, it makes wiring much easier
get an SAFC if you want piggy back fuel control
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Sep 4, 2005 - 11:29 PM
Snarfer
Joined Dec 2, '03
From Virginia
You don't need it I was just wondering how you were doing the setup. The relay board does make wiring a lot easier. After my friend and I soldered wires onto the sensors I think we did the final wireup in 10 mintues.
post Sep 5, 2005 - 12:23 AM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
megasquirt replaces ur ECU. i know a few ppl who have it
post Sep 5, 2005 - 10:50 AM
Snarfer
Joined Dec 2, '03
From Virginia
What kind of ignition does the 4a silvertop use? After looking at the megasquirt boards there have been people using msns -e and -edis on the stock systems without having to install a seperate vr wheel. I think I remember people mentioning vast, esa, and a few toyota dizzy/gm sensor systems. You might be able to setup a plug and play without having to alter too much on the engine
post Sep 5, 2005 - 11:11 AM
The AE101 4A-GE uses an ESA system I believe.
post Sep 5, 2005 - 9:54 PM
Snarfer
Joined Dec 2, '03
From Virginia
Here is a link from a guy getting an stock esa system to work with msns -e http://www.msefi.com/viewtopic.php?t=10564...ight=toyota+esa
You might need to join the board to access this.
He has access to a scope though which would make the job a lot easier, don't know how well a fluke meter would handle ignition pulses to diagnose the link.
This post has been edited by Snarfer: Sep 5, 2005 - 9:55 PM
Lo-Fi Version Time is now: August 23rd, 2026 - 10:57 PM
