> trd wing, installing
post Sep 21, 2005 - 6:07 PM
cyb593
Joined Feb 22, '04
From USA
ok if u look at my profile i have a 3 post spoiler that i am guessing came stock with the car. i am not sure if it is aftermarket or not anyways i need to know i have a trd wing and i know i need to atleast drill one more whole does anyone know if they other 2 holes will work with the wing without having to seal it and put another in??
This post has been edited by cyb593: Sep 21, 2005 - 8:48 PM
Replies (1 - 8)
post Sep 21, 2005 - 6:22 PM
QUOTE(cyb593 @ Sep 21, 2005 - 7:07 PM)
ok if u look at my profile i have a 2 post spoiler that i am guessing cam stock with the car. i am not sure if it is aftermarket or not anyways  i need to know i have a trd wing and i know i need to atleast drill one more whole does anyone know if they other 2 holes will work with the wing without having to seal it and put another in??
[right][snapback]337092[/snapback][/right]
in your profile i see 3 post spoilers.
if you have a 94-95 hatch, the TRD wing should be a bolt on thing, very easy. i konw mine was wink.gif
post Sep 21, 2005 - 7:08 PM
mark_426
Joined Jan 30, '05
From Greencastle, PA
If it is a direct bolt on from a 94/95, then the one back hole lines up. Then, you'll need to measure for the front one, and drill a hole, and then either drill a bigger hole, or dremel/burr grind a hole out for the bolt head. Its not a terrible job, just be careful. You will have exposed holes though. the most inside and rear hole, and the center ones.
post Sep 21, 2005 - 7:51 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
yea, you got the 3-post
i'd take it to a body shop, only ~2 of the like...8 holes are used.
center needs patched...
it's just a bunch of crap.
post Sep 21, 2005 - 8:48 PM
cyb593
Joined Feb 22, '04
From USA
sorry i meant 3 post just a typo anyways i have a 97 hatch though what does that mean??
post Sep 23, 2005 - 3:56 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
it means that the 94/95 have a 2 post spoiler, and if you had that (you don't) then the spoiler would bolt right on and things would be gravy. From 96/99 they have a 3 post spoiler. In this case the spoiler will not just directly bolt up, you will need to drill some holes to get it to fit. This will also leave your center spoiler holes (from stock spoiler) exposed. They will need to be filled.
**** Photobucket
post Sep 24, 2005 - 12:12 AM
cyb593
Joined Feb 22, '04
From USA
k thats what i was asking what do u do to fill the holes bondo then shave then touch up paint??
post Sep 24, 2005 - 4:46 PM
Consynx
Joined Dec 25, '02
i believe you can go a couple routes.
you can weld underneath and then just bondo fill
or you can be more practical and FG it, then bondo to smooth it out.
i just dont know how much weaker it will make the hatch to the stress the TRD will put on it, and if the bondo/FG will handle it.
This post has been edited by Consynx: Sep 24, 2005 - 4:47 PM
post Sep 28, 2005 - 9:34 PM
cyb593
Joined Feb 22, '04
From USA
could u just bondo it with out fg or welding??
Lo-Fi Version Time is now: May 17th, 2026 - 3:47 PM
