> cd player
post May 5, 2003 - 2:25 PM
98celica3
Joined Aug 30, '02
From North Carolina
got a question. My stock toyota cd player in my celi is f*cking up. it seems like when i go around right hand turns or curves it gets really staticy and sounds like it's skipping, but it's not skipping. what do you guys think could be the problem. my car is a 98.
adam
MISS THE CELI, BUT...
Replies (1 - 2)
post May 5, 2003 - 3:06 PM
runriot95
Joined Dec 1, '02
From Pittsburgh, PA
My guess is that it's a connection problem - a loose wire somewhere along the line. Either that or a damaged speaker. My guess is that the sharp turns are effecting the connection. I don't think it's anything with the player itself. If it's playing the disc and it's not skipping then I would say the problem lies somewhere AFTER the CD player. - Of course, that's just my opinion, I could be wrong.
post May 5, 2003 - 3:18 PM
Guest_Matthew_*
no you are right
check all your wires
here's what you do
use your fader and balance and do each speaker to its fullest and turn right
process of elimination will tell you where its at.
if that doesnt help then...get a voltage meter or something and have it touch the speaker terminals and turn right and see if the voltage drops really high or low..do that for each speaker
if that doesnt work...just re wire everything
if that doesnt work...get new speakers...
if that doesnt work...then its your deck
Lo-Fi Version Time is now: August 11th, 2026 - 9:03 PM
