Oct 9, 2005 - 2:17 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 23, '03 From New Orleans Currently Offline Reputation: 5 (100%) |
The spark plug wire set is not allowing me to get the spark plugs out. The thick part that actual goes over the plugs all popped off. They are all stuck ontop of the plugs. How in the world am I suppose to get them off? I've taken a long screw driver and tried to get them up as well as used the wire set itself to try to pull back up. Please help, is there a special tool for this problem or some type of technique. I've already tried our long needle nose but they wont open up in the small area. Thanks
Oct 9, 2005 - 3:03 PM
you need a super long set of needle nose pliars..or a big set of hemostats.
Oct 9, 2005 - 3:40 PM
Enthusiast ![]() ![]() Joined Jan 16, '04 From sydney australia Currently Offline Reputation: 0 (0%) |
Im not sure if i understand where your sparkplugs are BUT if they are stuck in the top of the motor and you cant get them outta there location try this....
cut a piece of garden hoes aprox 8" long then on one end cut two 1" slits on each side....place the cut end over the plug and press down and your plug will come out.... If your plug is not where i think it is you can use this tip some other time. -------------------- ![]() 312whp with more to come.... |
Oct 9, 2005 - 5:49 PM
the spark plug isnt what i cant get out right now, its the rubber part of the wires stuck ontop of the plug because they broke off whichi is my problem. thanks though, and i've tried the long set of needle nose, they wont open up.....this is a big pain in the butt
Oct 9, 2005 - 10:22 PM
![]() Enthusiast ![]() ![]() ![]() Joined Sep 12, '03 From Portland , Oregon , United States Currently Offline Reputation: -1 (33%) |
Search around, my buddy found at some random mom+pop store a 3' long set of needle nose's suprizlingy comes in handy quite often.
DTE -------------------- I am a thief.
do not buy anything from me. |
Oct 9, 2005 - 10:32 PM
ya, i'm going around tom. after work.
just to clarify, its the rubber part on the spark plug wires that is stuck ontop of the spark plug. I hate when cars dont want to be nice... thanks for the comments |
Oct 10, 2005 - 8:37 AM
chuco, look for a big set of hemostats, they will work perfectly.
just in case, "hemostats" are those little pliars the doctors use..or roach clips...lmao but you need a BIG set..my dad had a set in the toolbox for years... maybe sears or somthing. -------------------- Former Team 5SFTE pro member ;)
Oct 10, 2005 - 9:56 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
Chucho, you can also try pulling from the wire part of the spark plug wire, above the top of the plastic part and dust skirt that goes into the head.
If I understand what your saying correctly, then it sounds like the long plastic piece that has the dust skirt at the top has separated from the rubber part with the clip for the spark plug in the middle of it. Since the actual wire part goes through all that hard plastic as a way of preventing electronic interference you can probably just tug on the wire up higher using slow steady pulling. If its a no go, then use the hemostats like manny said or those little three-prong grabber claws that are made of jointed metal from Jegs or Summit, I believe. They have a handle so you can open and close the claw to grab things and they *could* do the trick if you have a steady hand and a flashlight. This post has been edited by Silver94CelicaOwner: Oct 10, 2005 - 10:00 PM -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Oct 10, 2005 - 10:01 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 29, '04 Currently Offline Reputation: 5 (100%) |
I'm guessing you were using wires other than stock toyota ones? I have tried both autozone AND advanced autoparts wires and after a few months they just get so crappy and brittle that they break when you try to pull them. Get wires from the toyota dealership, they cost about the same as the ones from any autoparts store, but these will last!
-Josh |
| Lo-Fi Version | Time is now: September 15th, 2026 - 3:24 PM |
