> Door Courtesy Lights in Blue
post Oct 29, 2005 - 10:30 PM
Zimluura
Joined Feb 3, '05
From USA/Virginia
just did the door courtesy lights. only a little bit left to do light wise. this job took like no time.
// How-To
Tools: Flat head screwdriver with 1 layer of duct-tape on head (so it doesn't scratch any plastic when you pry with it)
Parts: 2x Tundra Courtesy light lenses (mine were from a 2006 Tundra, Toyota Part Number: 81231-0C010), 2x num194 LEDs (http://autolumination.com/194.htm) the LEDs point directly outward so the 5led matrix is probably not needed.
// Disasembly
1. With the car off, open the door.
2. Put the flat-head screwdriver into the side of the courtesy light (i did the one towards the front of the car) and pry the light-housing out.
3. You should be able to pull the lens off of the light housing with your fingers.
4. The light-bulb *probably* isn't too hot to touch (mine were barely warm), so grab it and pull it out.
5. try inserting the num194 LEDs into the socket, if it doesn't light try rotating it 180 degrees (LEDs are sensitive to polarity).
// Troubleshooting
If, after being rotated 180 degrees, the LED still doesn't light make sure the contacts on the leds are touching the contacts in the socket. if they aren't you may need to modify the LED base a litte. The contacts on my LED base were too close together, so i carved some new grooves a little further out from the center with an x-acto knife, and then bent the LED contacts a bit, so they fit the new grooves.
Replies (1 - 14)
post Oct 30, 2005 - 12:22 AM
I used blue LEDs in mine and the lenses are $3.47 each at toyotaworld.com
post Oct 30, 2005 - 1:09 PM
Zimluura
Joined Feb 3, '05
From USA/Virginia
post Oct 30, 2005 - 2:21 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
how did you get your housing clear? mines red.
post Oct 30, 2005 - 2:36 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
Hey Dustin, did you use the part numbers at the top?
post Oct 30, 2005 - 3:04 PM
QUOTE(LewFX @ Oct 30, 2005 - 3:21 PM)
[right][snapback]350706[/snapback][/right]
did you read ? wink.gif the red lense is swapped with a clear lense from a Tundra.
QUOTE(dustin15brown @ Oct 30, 2005 - 3:36 PM)
[right][snapback]350712[/snapback][/right]
I actually bought mine from someone else, they had said they were from a Tundra.
post Oct 30, 2005 - 9:52 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
Hey D, what type of blue LED did you use? I know it's a 194. Guessing you got it from autolumination? Which style LED did you get? Looks awesome bro.
post Oct 31, 2005 - 12:29 AM
QUOTE(JoKeRkId613 @ Oct 30, 2005 - 10:52 PM)
[right][snapback]350843[/snapback][/right]
http://cgi.ebay.com/ebaymotors/2pcs-161-16...009900743QQrdZ1
item # 8009900743
post Jul 10, 2006 - 11:52 PM
nm
This post has been edited by Batman722: Jul 10, 2006 - 11:52 PM
post Jul 11, 2006 - 12:18 AM
hitcachi
Joined Jun 19, '05
From Nebraska
^ Hi my name is Dustin. I have a how to, with pics, for every single modification for the 6th gen celica. biggrin.gif Batman, you kick ass!
post Sep 29, 2009 - 4:05 PM
kagemidnight
Joined Jul 9, '09
From CT
QUOTE (Batman722 @ Oct 30, 2005 - 1:22 AM) *
oh well not the end of the world lol
post Sep 30, 2009 - 5:49 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
QUOTE (kagemidnight @ Sep 29, 2009 - 2:05 PM) *
Maybe $3.47 is the price it was 3 years ago when that post was made
post Sep 30, 2009 - 8:22 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
QUOTE (Batman722 @ Oct 30, 2005 - 12:22 AM) *
thats some nasty rust damn!
post Oct 1, 2009 - 1:46 AM
vincent_doggy
Joined May 25, '06
From Hong Kong
Here's mine
post Oct 2, 2009 - 10:03 PM
kagemidnight
Joined Jul 9, '09
From CT
Can't wait to see what it looks like installed, I think I'ma go with a bright white LED
Lo-Fi Version Time is now: August 23rd, 2026 - 10:31 AM
