> TWM Shortshifter, Install
post Nov 9, 2005 - 11:35 AM
TrdKing
Joined Feb 16, '05
From Brantford, Ontario, Canada
I was just wondering how the TWM shifter fits into the stock shifter.
How do you remove the old shifter because sometimes there is 4 bolt on top holding the rod in on mine there isnt it looks like a solid unit.
There are two small clipped in pieces facing door to door one in the front of the rod one in the back.
please help!!
Replies (1 - 7)
post Nov 9, 2005 - 11:41 AM
wait till you get the shifter directions with pictures are in the box and easy to follow
post Nov 9, 2005 - 11:15 PM
check the sticky in the interior forum. There is a pdf manual for the TWM SS in there in the 7th gen SS install post, I am hosting it. It has pics and all the instructions you will need.
post Nov 9, 2005 - 11:21 PM
Celicav
From Virginia
Thanks guys. I should be getting one soon too.
post Nov 9, 2005 - 11:40 PM
Valo666
Joined May 15, '05
From Toronto
its an easy install if u got the tools, took me less than an hour to install my 7th gen.
post Dec 25, 2005 - 2:38 AM
Celicav
From Virginia
I've got a few steps done on my TWM Shortshifter install, and all is going well so far. I am ready to undo the four 12mm bolts that hold the shifter assembly down. I don't have the right socket accessories at the moment, but here is what I think I am missing:
1) 6-inch extension (I only have a 3 inch right now - using a 3/8" drive ratchet)
2) universal joint (so that I can have flexible angle with ratchet)
Please confirm if this is sufficient. Thanks!
post Dec 25, 2005 - 4:47 AM
dlx742
Joined Oct 10, '05
From San Diego
i only used a 6 inch extension... it worked fine for me
make sure to put the spacers in underneath the shifter assembly... i didnt do that thinking that it wasnt necessary and found out the hard way when it felt like i had rocks in my shifter
post Dec 25, 2005 - 12:19 PM
Celicav
From Virginia
QUOTE(dlx742 @ Dec 25, 2005 - 2:47 AM) [snapback]370975[/snapback]
Looks like you have the 7th Gen shifter, from your profile. I purchased the one for the 6th Gen, and it does not need or come with the spacers...lucky me. But thanks for the advice on the extension.
Lo-Fi Version Time is now: August 29th, 2026 - 2:44 PM
