> 3sgte died..., Cut out on me...??
post Dec 16, 2005 - 7:44 AM
Celica_At_GT
Joined Sep 21, '02
From Melbourne, FL
Well here is a little history first (since haven't posted on this board much - use to a lot on cnet (celica.net) back in the day though....
I had done a 3sgte engine swap and had a buddy do all the wiring for me (about 3 years ago). After finishing the mechanical stuff and putting th engine in, I found out the wiring was hosed. I took it to a shop to get it looked at and they put a microtech standalone ecu in it.
I finally got it running and it ran great for about 2 hours of usage and then just died on me. I haven't been able to restart it since then (but haven't been working on it too much)...
The pistons all seem to have really low compression (all around 90-100 psi). I am wondering if
1. what the compression should be.
2. if it is low, why is it low on all of the cylinders - does this mean the head gasket may have been put on wrong?? What could this imply?
Thanks for any assistance.
Ben
Replies (1 - 19)
post Dec 16, 2005 - 8:04 AM
well, as for the compression #'s, if the motor is cold when you do it, the #'s will be lower overall.
did you hold the pedal to the floor when you did it?
post Dec 16, 2005 - 8:12 AM
Celica_At_GT
Joined Sep 21, '02
From Melbourne, FL
QUOTE(presure2 @ Dec 16, 2005 - 6:04 AM) [snapback]367961[/snapback]
I wasn't flooring it all the way, but I probably had aprox 75% open throttle...
This post has been edited by Celica_At_GT: Dec 16, 2005 - 8:20 AM
post Dec 16, 2005 - 9:34 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
Check for vacume leaks, check your fuses, double check everything. make sure everything is tight. its most likely something small causeing your problems
I will return one day.
post Dec 16, 2005 - 9:49 AM
Celica_At_GT
Joined Sep 21, '02
From Melbourne, FL
So I shouldn't worry about those compression numbers at all. What values are normal for a cold 3sgte engine (JDM)?
Thanks - I'll double check the everything and have the stand-alone do another self check w/ it's sensors... hopefully it's something small like you said...
post Dec 16, 2005 - 9:56 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
Check the sensors yourself, dont trust the standalone. its better to know for sure wink.gif
post Dec 16, 2005 - 10:28 AM
Celica_At_GT
Joined Sep 21, '02
From Melbourne, FL
QUOTE(defgeph @ Dec 16, 2005 - 7:56 AM) [snapback]367976[/snapback]
Good Call...should I do the same process/resistance chart for the jdm engine as the us version. I only have the table for the us versions...
post Dec 16, 2005 - 2:48 PM
compression should be around 164 or more. try doing the test again, and follow these directions.
http://www.celicatech.com/93rmsour/1993/93...em/compress.pdf
did you or anyone take the head off during your swap? why did you do the swap 3 yrs ago, and not work on the car since?
is the car cranking? are you gretting fuel or spark ?
why didnt you take the car back to the place that installed the stand alone as soon as you noticed that the car didnt want to run after 2 hrs.
post Dec 16, 2005 - 3:41 PM
Celica_At_GT
Joined Sep 21, '02
From Melbourne, FL
QUOTE(lagos @ Dec 16, 2005 - 12:48 PM) [snapback]368058[/snapback]
The head was taking off during the swap - new head gasket and ARP head studs put in. I haven't really been working on it much because I just started a new job and lived in an APT and couldn't have a spot to do massives amount of work.
Now I bought my house I can.
The shop went out of business so i'm hosed there. I was fighting with them for a while, but they where saying since they didn't do the entire swap - it must be other components. They weren't a very big help...
The starter is turning, and there's both fuel and spark... - running out of ideas...
Should the compression be 164 when it hasn't run, or after it warmed up? If it is after running, do you know what it should be when cold?
EDIT: as a side not - I don't think I put the head gasket on wrong - I've changed head gaskets/timing belts/etc... before but anything is possible I suppose...
This post has been edited by Celica_At_GT: Dec 16, 2005 - 3:44 PM
post Dec 16, 2005 - 3:57 PM
well... if you are getting spark and fuel, then chances are its not the ecu or harness...but you never know for sure with these things.
seeing as how you took the head off, there is a very good chance you might have done something wrong. you might not be getting a good seal. thats why its really a good idea not to mess with the head gasket unless you know its bad. you can never get as good of a seal as they did in the factory.
them min spec for compression is 128psi, so hot or cold, i think you need to get at least that in order for the car to start. google "compression test", there are a lot of tips and tricks to help you diagnose why the compression is that low.
when i bought my 3s, the guy who sold it did a cold test at my numbers were around 175 all accross. ... make sure you floor the gas pedal, pull out all the spark plugs, and watch the gauge as you are cranking it, every time you see the needle jump, thats 1 compression stroke. you should crank it for about 5 comression strokes.
post Dec 16, 2005 - 6:32 PM
Celica_At_GT
Joined Sep 21, '02
From Melbourne, FL
QUOTE(lagos @ Dec 16, 2005 - 1:57 PM) [snapback]368085[/snapback]
Yeah, that's what I figured also. I don't think it's piston seals etc, due to the the compressoin being low on all of the cylinders...
Thanks for all the info - I'll do the recommendations and see what I find out.
post Dec 16, 2005 - 8:18 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(lagos @ Dec 16, 2005 - 3:57 PM) [snapback]368085[/snapback]
I've never heard this. How could you never get as good of a seal? What if I replace my headgasket with a metal one? I've been debating plaining the head and putting in a metal head gasket. Sorry for the thread highjack Celica at GT. Wish I could help you, but I don't know enough.
Live Free, Be Happy
post Dec 16, 2005 - 9:12 PM
Celica_At_GT
Joined Sep 21, '02
From Melbourne, FL
QUOTE(Bigmeanbulldog55 @ Dec 16, 2005 - 6:18 PM) [snapback]368150[/snapback]
No worries - no that you mention that - I'm curious of it too...
post Dec 16, 2005 - 9:25 PM
QUOTE(Bigmeanbulldog55 @ Dec 16, 2005 - 8:18 PM) [snapback]368150[/snapback]
if the mating surfaces are not PERFECTLY flat, and SUPER clean, especially with a MHG, its will prolly leak at some point.
when your motor was at the factory being built, everything was brand new, and perfectly smooth and clean. wink.gif
i wouldnt say "never" get a good seal, but without the proper prep work (IE: machine work ect.) things are bound to go wrong at some point.
This post has been edited by presure2: Dec 16, 2005 - 9:26 PM
post Dec 16, 2005 - 9:28 PM
Rjb23
Joined Feb 8, '04
From KY
QUOTE(presure2 @ Dec 17, 2005 - 2:25 AM) [snapback]368158[/snapback]
Thats why you test it for flatness and get it machined if need be.
post Dec 16, 2005 - 10:11 PM
ok...i got a new saying then ....if it aint broke, dont fix it! lol
post Dec 17, 2005 - 7:23 AM
Celica_At_GT
Joined Sep 21, '02
From Melbourne, FL
QUOTE(lagos @ Dec 16, 2005 - 8:11 PM) [snapback]368173[/snapback]
Yeah, that was my mistake (just like taking it to a shop that went under shortly after having my car - I can write a book about the pains w/ the CC company to get my money back...)
I was always told to do a new head gasket/timing belt/etc... with the JDM engines though - just becuase they are put through such abuse...
So back to the issue, do you think it's a faulty job putting on the head gasket...?
post Dec 17, 2005 - 2:05 PM
did u redo the compression test? what were your numbers this time around?
post Dec 17, 2005 - 2:30 PM
afroman
Joined Feb 9, '03
From Sioux falls, South Dakota
just gonna throw this out there but i was always told that if all the numbers are relativly close on the test then everything is more than likely ok. people do test differently. compression test dont tell you a lot, it would be different if you had one way low or two way different from the others.
-Aaron-
post Dec 17, 2005 - 6:05 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
why didnt you go back to the shop that installed the standalone ECU and let them fix it. sounds to me llike something is not right there
Lo-Fi Version Time is now: August 27th, 2026 - 10:08 PM
