> info on JDM ecu speed cut. how can i eliminate it., search multiply forums.
post Dec 29, 2005 - 11:08 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
well i searched mr2oc, celica tech, and here.
i got all of "jdm ecu's have speed, a very easy thing to get rid of"
but i havent found anyhting that actaully tells you how.
so if anyone has info please let me know.
Replies (1 - 18)
post Dec 29, 2005 - 11:10 PM
jgreening
Joined Jan 17, '04
From Illinois
standalone or techtom. I am not aware of any other way but that doesn't mean it doesnt exist.
post Dec 30, 2005 - 1:16 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Do u mean the 180 KPH speed limit??
There is one wire that feeds into the ECU via the Speed sensor on the tranny, it also connects to the Speedometer on your dash. Cut that wire that feeds into the ECU and there u go! U will get a check light tho.
But what I found out is that when you hit Speed cut on your ecu, your pretty much close to redline cut anyways. So if you go at 120 MPH = 180 KPH. Your really close to rev cut limit. Its really pointless to cut it, but if you already have all the wires exposed go for it! That extra 10 MPH will do a little bit of good, but for a fact you will never go that fast on a straight lane.
post Dec 30, 2005 - 1:19 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
thanks for the help.
post Dec 30, 2005 - 2:00 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
I will return one day.
post Dec 30, 2005 - 4:20 AM
Insanity-74
Joined Jan 9, '05
From Under the car
Speed cut is a speed limiter. You can buy a small electronic gismo very cheap that if you put into the afore mentioned "cut" wire, will convert the speedo from KMPH to MPH thus making the speed limiter come in at 180MPH instead of 180KMPH, which of course is a speed you`ll never reach.
post Dec 31, 2005 - 9:36 AM
Mr_E
Joined Nov 16, '04
From UK
Nope. My blitz box is a full delimit, as the car was already converted to MPH and they left the 112mph limiter in place.
I got mine from ebay, from fensport they are not cheap.
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
post Dec 31, 2005 - 9:52 AM
Cutrara
Joined May 6, '05
From PA
This is only for ST Celicas, but it should give you a good idea.
post Dec 31, 2005 - 12:14 PM
Insanity-74
Joined Jan 9, '05
From Under the car
Well all they did to my car when it was imported was change the signal that goes to the speedo to turn it to MPH, still on the origional ECU and I`ve had mine way past 120mph (on the track of course)
post Jan 2, 2006 - 9:11 PM
eggman40
Joined Aug 17, '04
From California
A bit off topic but this thread got me thinking, when im done with the 3sgte swap and assuming that all the wiring is correct, what will my usdm speedometer read? will it be accurate with mph or will it be inaccurate because the ecu thinks its reading in KPH? thanks
This post has been edited by eggman40: Jan 2, 2006 - 9:11 PM
post Jan 2, 2006 - 10:05 PM
QUOTE(eggman40 @ Jan 2, 2006 - 9:11 PM) [snapback]373860[/snapback]
the speedo will be correct. the only difference is with the numbers they print out on the gauges, but the ecu and speedo motor all work the same.
what speed cut are you guys talking about? i think some of you are talking about fuel cut from too much boost presure?
post Jan 3, 2006 - 12:30 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
I don't know about the speedo, but just to make sure, I swapped out the Speedo on the tranny of the 7A USDM verison with the Speedo on the 4age 20V tranny. They are both interchangeable, and I don't seem to have any problems. Not sure if the JDM speedo will work with a USDM Gauge. The wiring is basically the same as well as the speedo plug.
post Jan 3, 2006 - 11:49 AM
recneps
Joined Jul 7, '04
From charlotte N.C.
QUOTE(lagos @ Jan 3, 2006 - 3:05 AM) [snapback]373879[/snapback]
japan has some kind of thing where they limit the max speed of a car, electronically, so people in skylines dont got 360kmh on japans freeways.
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Jan 3, 2006 - 12:32 PM
Mr_E
Joined Nov 16, '04
From UK
Correct. All JDM cars are limited to 180Kph (112mph)
JDM ST205
post Jan 3, 2006 - 11:27 PM
QUOTE(Mr_E @ Jan 3, 2006 - 12:32 PM) [snapback]374089[/snapback]
have to say i agree with the people in japan. there is no reason to go any faster then that
post Jan 4, 2006 - 12:53 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(lagos @ Jan 3, 2006 - 11:27 PM) [snapback]374316[/snapback]
I'll second that. Unless you've got a real high end drag car, there's no need to go any faster.
Live Free, Be Happy
post Jan 5, 2006 - 3:50 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
i think ive seen that you can put a switch on the speedo wire... just keep it on until you wanna go real fast them flip it off...i guess you will lose speedometer reading though smile.gif
post Jan 7, 2006 - 6:43 AM
ToysRfast
Joined Dec 11, '05
From MN, Rochester
HKS has the SLD speed limit defencer. I really can't say much about how it works since the instructions are in Japanese. But I do know it will stop the ECU speed limiter and let you go passed 180Km/h
post Jan 9, 2006 - 10:35 AM
Mr_E
Joined Nov 16, '04
From UK
QUOTE(Bigmeanbulldog55 @ Jan 4, 2006 - 5:53 AM) [snapback]374351[/snapback]
Or, for example, want to commute to work in Germany. Or enjoy some track work. Or any number of other reasons not to have a speed cut.
JDM ST205
Lo-Fi Version Time is now: September 2nd, 2026 - 3:38 PM
