> Water leaking drivers side, Any ideas?
post Dec 31, 2005 - 7:00 PM
ScoobyDooCruiser
Joined Oct 31, '02
From Boise, ID
Hey,
I've been having some problems with my celi leaking on the drivers side. I can't figure out where the water is coming from. The entire driver side floor area, as well as the driver side back seat area are soaked.
Does anyone know if some pineneedles might have clogged something with the heater? Or what? I don't have any wheel well liners (the plastic things inside the wheel well), so would that have anything to do with it? Does anyone have any ideas? Please let me know
psalm 69
Replies (1 - 8)
post Dec 31, 2005 - 10:11 PM
the same thing is happening to me...it is my windshield, the upper driver's corner. If I stand outside the car and reach in and push it out, I can see it move. Wind noise is louder now too. I'll be changing that myself in a few months.
post Jan 2, 2006 - 5:30 PM
speedyrider
Joined Aug 16, '05
From Belgium
could be the inner radiator.
the one for warming the interrior
post Jan 2, 2006 - 9:45 PM
mikew04
Joined Feb 19, '04
From austin tx
QUOTE(speedyrider @ Jan 2, 2006 - 5:30 PM) [snapback]373795[/snapback]
aka heater core. you would be losing coolant of that is what is causing it tho, and your windows would fog up very easily with the heater on and you would also be able to smell it.
do a search, there's a few posts about this. check the area around your sunroof and around the doors, there are water passages for drainage that run through the car and alot of it is rubber lines which can become damaged or blocked.
post Jan 3, 2006 - 12:20 AM
QUOTE(mikew04 @ Jan 2, 2006 - 9:45 PM) [snapback]373871[/snapback]
true and also the heater core is located above the passenger side foot area, not the driver's side. When the heater core leaks, the pass side gets 95% of the coolant and it is hard to miss.
post Jan 3, 2006 - 1:36 AM
Jaws4God
Joined Mar 27, '04
I had the same problem.. Found it to be leaking through the door wires entering the car. Just added some sealant and hadn't had a problem since..
post Jan 3, 2006 - 2:16 AM
popstar
Joined Nov 24, '04
From Moscow, russia
i get a build up of condensation above my roof lining with i drive alot with heating on at sub-zero temps, and it's worse if i have passangers..... then i get water dripping on my leg from the 'sun visor' bracket where it's fixed to the head linner !!!!!!!
Life is for living, and you don't get a second chance
Take care now !!
post Jan 3, 2006 - 1:19 PM
ScoobyDooCruiser
Joined Oct 31, '02
From Boise, ID
QUOTE(Jaws4God @ Jan 2, 2006 - 10:36 PM) [snapback]373974[/snapback]
What door wires?
psalm 69
post Jan 3, 2006 - 3:49 PM
xquickwitx
Joined Aug 16, '03
From Shreveport, Louisiana
yeah my car does this too. I noticed it happen alot after a bad rain. I was talking to a windshield guy that had to replace my supra windshield before I bought it. He said some sealant opened up at the base of the windshield (behind the plastic by the wipers). just run some weather sealant where glass meets metal under the plastic. That fixed me up. thumbsup.gif
Lo-Fi Version Time is now: August 26th, 2026 - 8:52 PM
