> rattle
post Jan 4, 2006 - 4:35 PM
97rocket
Joined Aug 2, '05
From ohio
i just got new tyres put on my 97 celica hoping it would fix the rattle @ high speeds now im thinking its the front brake rotors and ideas?
Replies (1 - 8)
post Jan 4, 2006 - 5:47 PM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
Is the suspension ok? No springs broken?
JDM ST205
post Jan 4, 2006 - 6:30 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Get the wheels/tires re-balanced.
This post has been edited by Kwanza26: Jan 4, 2006 - 6:31 PM
post Feb 9, 2006 - 5:04 PM
97rocket
Joined Aug 2, '05
From ohio
i have another question my cars manual and ill leave it in 1st gear and go to 4 or 5 thousand rpms and let go of the gas and it slows down like it should but then sometimes the brake light comes on.
post Feb 9, 2006 - 5:14 PM
creis
Joined Jan 10, '04
From Shoreline, WA
^ thats odd, probably bumping the brake light power cable.
I say rebalance the wheels, sometimes the little weights can get knocked off or just come lose.
post Feb 9, 2006 - 6:00 PM
Verde97
Joined Aug 20, '03
From Kansas City
QUOTE(creis @ Feb 9, 2006 - 4:14 PM) [snapback]391406[/snapback]
Agreed. Sticker weights pop off sometimes.
post Feb 9, 2006 - 6:23 PM
miro1975
Joined Nov 23, '05
From Charleston, WV
Go with sticker weight inside in your wheel and outside weight (normal weight on the edge of the wheel from inside). That 's the best option... I had a same problem before. Check your wheels. Are they straight? Are they after market or stock toyota? I'v got after market before and had a lot of vibrations at speed aroud 70 mph and more. And one more thing. Go to some place good, with calibrated balancers. Some time that's makes a big difference.
Hope I helped a little...
post Feb 28, 2006 - 1:40 PM
Nigel
Joined Aug 21, '03
From UK Liverpool
if its a uneven rattle sometimes you can get stones inside the tire. if its a ticking then could be CV joint
post Feb 28, 2006 - 2:58 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
sway end links can cause a rattling noise if not tight or wear and tear
Lo-Fi Version Time is now: August 26th, 2026 - 8:59 PM
