> sick of low pros, options on 17s
post Jan 12, 2006 - 11:21 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
obviously some newer cars have larger wheels, some are 17inch and they don't have low profile tires. Is there anyway I can put non-low-profile tires on my 17 inch motegis? Can I have the speedometer adjusted to compensate for the added diameter? I want more or a sidewall, and I actually like the look of taller wheels.
Replies (1 - 4)
post Jan 13, 2006 - 2:25 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
ok, well, I'm sure I could easily find this answer from a local autotire. I was just hoping to get an answer from the comfort of my own room. rolleyes.gif
post Jan 13, 2006 - 8:11 AM
yes you can have your speedometer recaliprated but it will cost you some amount...
and for tires you can fit a 45 probably even a 50 since your not lowered...well your pics don't show a drop so ehh....should just look at tire rack
This post has been edited by playr158: Jan 13, 2006 - 8:24 AM
post Jan 15, 2006 - 3:02 AM
Speedy2k
Joined Jan 6, '06
From Toronto, Canada
Why do you care so much that your speedometer wont be accurate anymore. You can easily figure out how much your speedometer will be affected. So when ur speedometer will say 100km/h you will know that you are going 102 or 103 for example. Id get like 225/45/17 and dont worry about your speedometer.
post Jan 15, 2006 - 3:13 AM
agreed, the speedo what be a problem and youll get good ride quality
Lo-Fi Version Time is now: August 27th, 2026 - 12:58 AM
