Jan 19, 2006 - 12:04 AM
![]() Enthusiast ![]() ![]() Joined Jan 13, '06 Currently Offline Reputation: 0 (0%) |
any body know the oil pressure i should be getting at the TEE next to the filter on the 7AFE? around what?
Jan 19, 2006 - 1:27 AM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) |
QUOTE(southwest2118 @ Jan 19, 2006 - 12:04 AM) [snapback]380744[/snapback] any body know the oil pressure i should be getting at the TEE next to the filter on the 7AFE? around what? i think it is around 53-60 psi on a cold start -------------------- ![]() |
Jan 19, 2006 - 1:33 AM
from the BGB the oil pressure is around 3.8 to 71 psi This post has been edited by Batman722: Jan 19, 2006 - 1:33 AM -------------------- |
Jan 20, 2006 - 8:00 PM
whats BGB?
Jan 20, 2006 - 10:37 PM
big giant book.....toyota's handbook on the celica
but yea normal running pressure as batman says is 71 (too high for a turbo |
Jan 20, 2006 - 10:41 PM
QUOTE(southwest2118 @ Jan 20, 2006 - 8:00 PM) [snapback]381656[/snapback] whats BGB? Big Green Book -------------------- |
Jan 20, 2006 - 11:32 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
i get 45 or so at startup/ under throttle. At rest and warmed up the oil pressure should be like 5
Jan 20, 2006 - 11:35 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
45 is right around where you want it when warmed up and under throttle, generally.
71 is more like when you just started it and it's COLD. Even then... that's pretty high and not normally seen. -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Feb 6, 2006 - 7:20 PM
at start up i get like 50 and under throttle its like 60 at rest its like 3... dose that sound ok??
This post has been edited by southwest2118: Feb 6, 2006 - 7:20 PM |
Feb 6, 2006 - 11:04 PM
QUOTE(southwest2118 @ Feb 6, 2006 - 7:20 PM) [snapback]389801[/snapback] at start up i get like 50 and under throttle its like 60 at rest its like 3... dose that sound ok?? Yes -------------------- |
Feb 7, 2006 - 7:15 AM
-3an piping or Restrictor ??
Feb 10, 2006 - 11:46 PM
??? its for a rebuilt t3 .42/.48 A/R??
Feb 11, 2006 - 1:46 AM
They say you're supposed to use a restrictor if the pressure goes over 50 under load...so then yes.
I've heard of people using them and blowing their turbos, and I've heard of people using them and having great results. I've heard of people not using them and blowing their turbos, and I've heard of people not using them and having great results. Choose your poison. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Feb 11, 2006 - 1:52 AM
come on doc what do you do?
Feb 11, 2006 - 2:44 AM
It's on a case by case basis.
I buy the restrictor, but don't use it, and then I measure the oil pressure right at the turbo. If it's within reason then I go without it and if the turbo doesn't smoke, then I don't use it. If it smokes, then I install it. Either way I give it to the customer to keep so that if the turbo starts to leak oil down the road, they can put it in (if the oil pressure is the problem). -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Feb 11, 2006 - 3:01 AM
at WOT I'm at 60 psi....so i should try just running any size to the turbo if it starts to give me problem buy restrictor.?
Feb 11, 2006 - 3:07 AM
QUOTE(southwest2118 @ Feb 11, 2006 - 8:01 AM) [snapback]392125[/snapback] at WOT I'm at 60 psi....so i should try just running any size to the turbo if it starts to give me problem buy restrictor.? Well, don't run anything bigger than -3 AN or 1/8" which is what it's equal to. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Feb 11, 2006 - 3:15 AM
other then the internet where can i get those sizes? and steel braided? i have female 1/8" npt on the Tee from the block and the turbo.
hey doc you think i can run 5 psi with no fuel mods? from the compressor housing to the Wastegate, should there be a boost controller? Like Nik? This post has been edited by southwest2118: Feb 11, 2006 - 3:20 AM |
Feb 11, 2006 - 3:53 AM
QUOTE(southwest2118 @ Feb 11, 2006 - 8:15 AM) [snapback]392130[/snapback] other then the internet where can i get those sizes? and steel braided? i have female 1/8" npt on the Tee from the block and the turbo. hey doc you think i can run 5 psi with no fuel mods? from the compressor housing to the Wastegate, should there be a boost controller? Like Nik? Typically I order all my AN stuff online, I can't get it anywhere locally. However, since you have a 1/8" npt on both the tee from the block and the turbo, you can just run a 1/8" high pressure line (like a hydralic line, you can get these at pretty much any parts store) with clamps. Of course you'll need a 1/8" barbed fitting for the line to fit over. Then you don't have to mess with any of the stainless AN stuff (although that looks a lot nicer). No. If you know what the wastegate is set to then you don't need it, no. For that matter, you cannot run anything LESS than what the wastegate is set to, a boost controller will only allow you to run MORE boost. (For example, if the wastegate is set to 7 psi, you can set the boost controller to run 8 or 9 psi, but you cannot set it to run 5 or 6 psi. The wastegate setting is the MINIMUM.) -Doc This post has been edited by Dr_Tweak: Feb 11, 2006 - 3:55 AM -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Feb 11, 2006 - 3:56 AM
how do i know what the wastegate is set to?.........
you think i can get away with a fmu and a bigger pump? |
Feb 11, 2006 - 3:58 AM
Normally you find out from whoever you buy the turbo from.
Yes, as long as you run no more than 7 psi, at that point the pressure gets so high when using an FMU that the injectors have trouble opening. And you should still get an MSD Boost Timing Master to retard the timing under boost. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Feb 11, 2006 - 3:59 AM
you think this will work PN# EAR-981603ERL x2 on http://store.summitracing.com/ and the line?
or i should get ONE with a 90 or 45 degree bend. |
Feb 11, 2006 - 4:03 AM
Yeap you'll need two of those and two of these: EAR-600103ERL
And of course some stainless -3 AN line. You may want to use a 90 degree on the top of the turbo, depending on how your route everything... -Doc This post has been edited by Dr_Tweak: Feb 11, 2006 - 4:06 AM -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Feb 11, 2006 - 4:10 AM
****....let me sleep on it QUOTE(Dr_Tweak @ Feb 11, 2006 - 2:58 AM) [snapback]392143[/snapback] Normally you find out from whoever you buy the turbo from. Yes, as long as you run no more than 7 psi, at that point the pressure gets so high when using an FMU that the injectors have trouble opening. And you should still get an MSD Boost Timing Master to retard the timing under boost. -Doc |
Feb 11, 2006 - 4:16 AM
2-EAR-600103ERL Fitting, Hose End, Speed-Seal, Straight, -3 AN Hose to Female -3 AN, Steel, Zinc Plated, Each $5.25 $10.50
1-EAR-981603ERL Fitting, Straight, -3 AN Male to 1/8 in. NPT Male, Aluminum, Blue, Each $1.75 $1.75 1-RUS-660790 Fitting, 90 Degree, -3 AN Male to 1/8 in. NPT Male, Aluminum, Blue, Each $6.95 $6.95 ok what hose? can't i make my own on this site with the end connections i want? |
Feb 11, 2006 - 4:18 AM
http://store.summitracing.com/partdetail.a...15&autoview=sku
This post has been edited by Dr_Tweak: Feb 11, 2006 - 4:19 AM -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Feb 11, 2006 - 4:20 AM
will i need to retard timming if i use a ?safc2? and some bigger injectors?.........
Feb 11, 2006 - 4:23 AM
what if i get rid of the 2 x speed seal end pieces and get this EAR-63010114ERL
or this will be better EAR-63010121ERL ...yaa...i'ma go to sleep This post has been edited by southwest2118: Feb 11, 2006 - 4:26 AM |
Feb 11, 2006 - 5:32 AM
QUOTE(southwest2118 @ Feb 11, 2006 - 9:20 AM) [snapback]392150[/snapback] will i need to retard timming if i use a ?safc2? and some bigger injectors?......... Yes, but if you use larger injectors and the Greddy e-manage or the Perfect Power SMT6 then you don't since they both have timing control. QUOTE(southwest2118 @ Feb 11, 2006 - 9:23 AM) [snapback]392151[/snapback] what if i get rid of the 2 x speed seal end pieces and get this EAR-63010114ERL or this will be better EAR-63010121ERL ...yaa...i'ma go to sleep You'd have to measure them to see what length you need, but if the length is right then yeah, they would work. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Feb 11, 2006 - 8:29 AM
QUOTE(Dr_Tweak @ Feb 11, 2006 - 2:44 AM) [snapback]392121[/snapback] It's on a case by case basis. I buy the restrictor, but don't use it, and then I measure the oil pressure right at the turbo. If it's within reason then I go without it and if the turbo doesn't smoke, then I don't use it. If it smokes, then I install it. Either way I give it to the customer to keep so that if the turbo starts to leak oil down the road, they can put it in (if the oil pressure is the problem). -Doc thats exactly what everyone who turbos should do. good call doc. also if you dont wanna hassle with all that feed line stuff, just measure what length you need. decide which ends you want, and call atpturbo theyll custom make you a stainless braided -3an line for a good price. mine is 20" total length, and it was 28$ i did make my own oil filter relocation lines, tho, and if thats the way you decide to go, its not really that hard at all to do, once you get the hang of it. This post has been edited by presure2: Feb 11, 2006 - 8:33 AM -------------------- Former Team 5SFTE pro member ;)
Feb 14, 2006 - 1:42 AM
where do i buy a -3an oil feed line for my turbo? with two females? can't find it on summit
Feb 14, 2006 - 2:10 AM
If it's a stainless braided -3 AN line, then it will be fine. They're made for high temp, high pressure applications.
Feb 14, 2006 - 7:12 AM
QUOTE(Dr_Tweak @ Feb 14, 2006 - 1:10 AM) [snapback]393585[/snapback] If it's a stainless braided -3 AN line, then it will be fine. They're made for high temp, high pressure applications. -Doc but that stuff is made for brakes? link me up to something thats 20" please |
Feb 14, 2006 - 7:49 AM
if your making it yourself, you need to buy a preset amount, and cut it to length.
www.ATPTURBO.com can make the line for you if you dont wanna make it yourself. -------------------- Former Team 5SFTE pro member ;)
Feb 15, 2006 - 10:13 PM
Enthusiast Joined Nov 29, '05 From Florida Currently Offline Reputation: 0 (0%) |
or just buy a t3/t4 oil feed line kit for like $70
(but yeah its probally cheaper from like summit piece by peice ) t3/t4 oil feed line kit This post has been edited by Smokeeey420: Feb 15, 2006 - 10:15 PM |
Jan 1, 2007 - 4:24 AM
Enthusiast ![]() Joined Oct 27, '05 Currently Offline Reputation: 0 (0%) |
sorry for to bring this thread back alive since nearly 1 yr.not sure what am i asking issit revelant to this topic.
dont majority of the 7afe shld have about the same reading of oil press? i do know weather temp play apart. What other factor could cause the oil press goes abnormal high? i've my turbo replaced twice in yr 2006 alone and my mech was suspecting my oil press too high for turbo to handle. im using rhb52, 10-40w semi-syn oil. |
Jan 1, 2007 - 6:15 PM
it seems like everyone who turbos the 7a has the problem of overfeeding the turbo.
most everyone who does it now includes the restrictor inline with the feed line. -------------------- Former Team 5SFTE pro member ;)
Jan 1, 2007 - 8:49 PM
QUOTE(presure2 @ Jan 1, 2007 - 6:15 PM) [snapback]514439[/snapback] it seems like everyone who turbos the 7a has the problem of overfeeding the turbo. most everyone who does it now includes the restrictor inline with the feed line. As im new in charging my 7AFE, so its common issue that most of them faced in turbocharging thier 7AFE? |
Jan 1, 2007 - 9:38 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
I've had to rebuild my turbo every year and it's getting close to time to do it again. It smokes sometimes and always stinks of burnt oil.
Jan 2, 2007 - 1:09 AM
jeeze guys, its a KNOW ISSUE that the 7afe has high oil pressure and you need a restrictor on the oil feed line. its just a brass piece that has a small hole in the middle of it, it stops too much oil from getting to the turbo.
Jan 2, 2007 - 1:50 AM
Well thanks for enlightening us with your knowledge and smarts, Captain Obvious.
I kid...I kid. -------------------- |
Jan 2, 2007 - 2:41 AM
ok. got it thn. Tks for it
Jan 4, 2007 - 7:51 PM
i ran a restrictor for about two months till it broke...i was trying to take the line off and it snapped cheap ATP crap
| Lo-Fi Version | Time is now: June 9th, 2026 - 6:14 AM |
