Jan 22, 2006 - 1:28 AM
Enthusiast ![]() ![]() ![]() Joined Aug 14, '05 From St. Paul, MN(USA) Currently Offline Reputation: 8 (100%) |
I was always curious of how to tell if the MR2 tranny was LSD(meaning the tranny is out of engine bay not connected to motor)? I was told that if you look though the axel hole, there should be a bar going across, but if a bar runs across the axle hole then how would the axle go in? Some body who knows please post...
Jan 22, 2006 - 1:51 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
QUOTE(team_omega @ Jan 22, 2006 - 6:28 AM) [snapback]382162[/snapback] I was always curious of how to tell if the MR2 tranny was LSD(meaning the tranny is out of engine bay not connected to motor)? I was told that if you look though the axel hole, there should be a bar going across, but if a bar runs across the axle hole then how would the axle go in? Some body who knows please post... Actually it's vise-versa. If you pull the axle and look in there, and there is a pin (the diff pin) visible, then you do NOT have LSD, it's an open diff. If there is no pin, then it's a Helical LSD. The pin is deep in there, it doesn't interfere with the axle going in. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Jan 22, 2006 - 1:54 AM
QUOTE(Dr_Tweak @ Jan 22, 2006 - 1:51 AM) [snapback]382173[/snapback] QUOTE(team_omega @ Jan 22, 2006 - 6:28 AM) [snapback]382162[/snapback] I was always curious of how to tell if the MR2 tranny was LSD(meaning the tranny is out of engine bay not connected to motor)? I was told that if you look though the axel hole, there should be a bar going across, but if a bar runs across the axle hole then how would the axle go in? Some body who knows please post... Actually it's vise-versa. If you pull the axle and look in there, and there is a pin (the diff pin) visible, then you do NOT have LSD, it's an open diff. If there is no pin, then it's a Helical LSD. The pin is deep in there, it doesn't interfere with the axle going in. -Doc What if i don't have the axles and only the tranny? Then how do i tell? |
Jan 22, 2006 - 3:21 AM
You don't need the axles at all, you need to remove the axles if they are installed, and look in the hole in the tranny that they would go in.
Jan 22, 2006 - 10:59 PM
QUOTE(Dr_Tweak @ Jan 22, 2006 - 3:21 AM) [snapback]382201[/snapback] You don't need the axles at all, you need to remove the axles if they are installed, and look in the hole in the tranny that they would go in. -Doc Thanks for the info Doc |
Jan 22, 2006 - 11:30 PM
Does your axle hole look like:
this ![]() this ![]() or this?
This post has been edited by Supersprynt: Jan 22, 2006 - 11:43 PM -------------------- |
Jan 23, 2006 - 12:39 PM
Enthusiast ![]() ![]() Joined Apr 7, '04 From Toronto Currently Offline Reputation: 3 (100%) |
If you see a bar going across is also considered an lsd tranny
I think there are 2 kinds of lsd tranny for the mr2 the one with the bar 2nd one would be a big hole followed by the a small hole The one with the bar across, I'm 100 % positive that it is an lsd coz thats what I have on my car right now. the 2nd one, I'm not too sure about it. Please correct me if I'm wrong |
Jan 23, 2006 - 12:45 PM
To MY knowledge, which contradicts Doc's and I dont like that, is that the bar means OEM LSD (2nd pic), the top pic is an open differential and the bottom is TRD LSD.
Jan 23, 2006 - 1:39 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) |
The bar denotes the LSD. Here are some threads:
Thread #1 Thread #2 Thread #3 Thread #4 Thread #5 Thread #6 Thread #7 Thread #8 There are more, but I think you get the idea. There are posts in these threads from Jeff Fazio, BillWot, and Josh at Chico Race Works confirming the same thing. HTH. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Jan 23, 2006 - 11:29 PM
QUOTE(Supersprynt @ Jan 23, 2006 - 5:45 PM) [snapback]382750[/snapback] To MY knowledge, which contradicts Doc's and I dont like that, is that the bar means OEM LSD (2nd pic), the top pic is an open differential and the bottom is TRD LSD. I think you're right actually, I was going by how we tell with the E58 tranny which is the same thing as an E153 internally (pretty much), and I figured they would be the same... I can't see a difference between the top and bottom pics though... -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Jan 30, 2006 - 12:52 AM
QUOTE(Supersprynt @ Jan 22, 2006 - 11:30 PM) [snapback]382575[/snapback] Does your axle hole look like: this ![]() this ![]() or this? ![]() I dont see anything like those pic on my tranny? And what is the difference between open differantial and LSD(what it does)? I know LSD spins both wheels but what does open differantial do? |
Feb 6, 2006 - 1:42 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
correct me if am wrong but another way to tell if the tranny is equiped with lsd is when the axles are in place and you spin one wheel (while car is in air) the other wheel should spin in the same direction. Ex. if you turn the left wheel forward, than the right wheel should spin forward, and vice versa. if there is no lsd, then the wheels would spin opposite from each other. EX. push right tire forward, left wheels spins backward.
Feb 6, 2006 - 1:48 AM
QUOTE(eggman40 @ Feb 6, 2006 - 12:42 AM) [snapback]389517[/snapback] correct me if am wrong but another way to tell if the tranny is equiped with lsd is when the axles are in place and you spin one wheel (while car is in air) the other wheel should spin in the same direction. Ex. if you turn the left wheel forward, than the right wheel should spin forward, and vice versa. if there is no lsd, then the wheels would spin opposite from each other. EX. push right tire forward, left wheels spins backward. Depends on the type of LSD you have. This method does not work for a stock LSD in an E-153. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Feb 6, 2006 - 1:52 AM
Depends on the type of LSD you have. This method does not work for a stock LSD in an E-153. [/quote] this did happen to me when i put in my 92' e-153 in, and i do have that bar accross the hole in the picture, so does that mean my lsd is not stock or what? |
Sep 17, 2006 - 10:26 PM
Enthusiast ![]() Joined Mar 30, '05 From Wisconsin Currently Offline Reputation: 0 (0%) |
how can u tell is a lsd,
if i look in that axle hole i can see through the other side that does has a pin, that block both axle. what if have pin in the middle of center... the picture i am talk about the 2nd picture. that spose to be non lsd or lsd |
Sep 17, 2006 - 10:47 PM
QUOTE(funnys_tears @ Sep 17, 2006 - 10:26 PM) [snapback]480858[/snapback] how can u tell is a lsd, if i look in that axle hole i can see through the other side that does has a pin, that block both axle. what if have pin in the middle of center... the picture i am talk about the 2nd picture. that spose to be non lsd or lsd 2nd pic is LSD |
Sep 21, 2006 - 12:09 AM
my axle hole looke the 2nd picture then..wow i am lucky then i has lsd then, that awsome.. welp i got my from 3sge gt-r modle..hehehhe
Sep 21, 2006 - 9:19 PM
QUOTE(funnys_tears @ Sep 21, 2006 - 12:09 AM) [snapback]482112[/snapback] my axle hole looke the 2nd picture then..wow i am lucky then i has lsd then, that awsome.. welp i got my from 3sge gt-r modle..hehehhe the mr2 lsd have it...but it is kind of heard to explain...for example the mr2 lsd will have the bar in the hole and the mr2 non-lsd will not...but on the celica gt/st etc....the tranny has the bar in the hole too but doesn't have lsd...so i recommend you take the transmission id number to the dealer and look it up or i can do it for you...just pm me the transmission ID number.... |
| Lo-Fi Version | Time is now: August 26th, 2026 - 7:38 PM |
