Jan 26, 2006 - 3:56 PM
Enthusiast ![]() ![]() ![]() Joined Oct 10, '04 From New Jersey Currently Offline Reputation: 0 (0%) |
i just got home last night and my car began to overheat but the temp guage was fine so i thought it was the thermostat or something small like that. so this morning i get up to go to the gas station and all i here is a loud knocking sound coming from the engine. iam guesing i either melted a piston or threw a rod. iam gonna start taking the engine apart to day and see whats up with it. ill keep every one posted. on the bright side hopefully this means a 3sgte swap soon
Jan 26, 2006 - 4:15 PM
Enthusiast ![]() ![]() ![]() Joined Sep 29, '02 From Sterling Heights, Michigan Currently Offline Reputation: 0 (0%) |
Sounds like a rod knock to me. It's common with the 7afe. Mine blew about 2 months ago. Had to get it relplaced.
Jan 26, 2006 - 6:02 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 16, '06 From Lima, ohio Currently Offline Reputation: 0 (0%) |
thrown rod, my brother did it to his mazda, threw rod undre counterweight and shredded the piston
Jan 26, 2006 - 6:28 PM
i took the spark plugs out and their was no damage. i took the valve cover off and some bolts to the head but its too cold so ill do the rest tomorrow. allso, the intake to the 4th piston is all covered in oil and burned, what could that be??
Jan 26, 2006 - 7:35 PM
Enthusiast ![]() ![]() ![]() ![]() Joined May 3, '04 From pittsburgh Currently Offline Reputation: 0 (0%) |
QUOTE(StreetRacing10PSI @ Jan 26, 2006 - 11:28 PM) [snapback]384926[/snapback] i took the spark plugs out and their was no damage. i took the valve cover off and some bolts to the head but its too cold so ill do the rest tomorrow. allso, the intake to the 4th piston is all covered in oil and burned, what could that be?? one of the cylinders burnt up the oil that was comin into it and since ur engine was straved of oil u prob threw a rod..happened to my dsm....my advise..swap time!!!..naw, j/k if u have the money its time or it..or my advice build the 7a for boost!! -------------------- ![]() Now SR powered |
Jan 26, 2006 - 7:44 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 24, '03 From fort smith, ar Currently Offline Reputation: 0 (0%) |
you threw a rod. i did the same thing just before new years day...no more celica for me.
-dstrb -------------------- ![]() former celica owner. |
Jan 27, 2006 - 7:39 AM
if its a rod i think iam just gonna swap the engine for a 3sgte. i would build the 7a for boost but their are no good piston and rod combos out their plus i have an automatic trans and i really wanna get rid of that.
Jan 27, 2006 - 7:47 AM
im gonna say cracked/broken ringland
Jan 27, 2006 - 5:03 PM
i pulled the oil pan today and found chuncks of the rob bearing in the pan, so iam going to replace them for now and as soon as i sell my ATV iam going to sell my turbo kit and get ready for a 3sgte swap. i should have some were around 4,500.00 after i sell my ATV and turbo kit, and ill have a nother car for around 3 weeks so i think that would b a good time to do it.
| Lo-Fi Version | Time is now: June 14th, 2026 - 2:46 PM |
