> rear suspension- wacky ass bolt?, allen wrench/nut combo? wtfbbq?
post Mar 4, 2006 - 11:54 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
how the **** do you get this ****ing ********* *** **************** off? it's an allen key bolt with a nut on it and i'd assume you have to wrench the nut whilst holding the bolt still with the allen key. but, this is ****ing impossible, or so it would seem. how have you guys taken this **** off?
This post has been edited by jayi12-15psi: Mar 5, 2006 - 12:08 AM
Replies (1 - 12)
post Mar 5, 2006 - 12:12 AM
it is called a "sway bar end link"
read this
http://www.6gc.net/forums/index.php?showtopic=13931
and this
http://www.6gc.net/forums/index.php?showtopic=33005
post Mar 5, 2006 - 12:14 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
QUOTE(Batman722 @ Mar 4, 2006 - 11:12 PM) [snapback]402758[/snapback]
thanks nigga
post Mar 5, 2006 - 12:39 AM
geeeze you newb can't you stinkin search yo?!
wat B you tinkn son!?
ha just playin PB blaster is your friend on this one
This post has been edited by playr158: Mar 5, 2006 - 12:40 AM
post Mar 5, 2006 - 3:54 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
QUOTE(playr158 @ Mar 4, 2006 - 11:39 PM) [snapback]402764[/snapback]
how in the name of ****ing jesus? this requires about 200 times the amount of torque you can possibly apply with either a regular wrench or a ****ing allen key. i sawzalled that **** to buddhist nirvana and then **** on its grave.
post Mar 5, 2006 - 5:45 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
thanks nigga[quote]
sorry, that wasn't me, I apologize to anyone offended.
post Mar 5, 2006 - 11:16 AM
azian_advanced
Joined Apr 18, '05
From Calgary
wd40 then torch it real hot. repeat again and again til it loosens. don't overtorque it and ruin the key. be careful not to do both at the same time and burn yourself tongue.gif and be careful to keep the heat away from brake lines and struts.
post Mar 5, 2006 - 12:14 PM
Clipsetuner
Joined Sep 12, '03
From Portland , Oregon , United States
These piss'ed me off so bad.... Mine wouldent budge a inch no matter PB blaster / WD40, I ended up just drillin them out, but if you cant get them off there like 40$ each from the dealership eh...
DTE
I am a thief.
do not buy anything from me.
post Mar 5, 2006 - 12:54 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
QUOTE(Clipsetuner @ Mar 5, 2006 - 11:14 AM) [snapback]402868[/snapback]
DTE
dte? what's that nigga
post Mar 5, 2006 - 1:06 PM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
Use a hex head piece with a socket.
With a socket wrench, you'll be able to apply far more torque than you ever will with a piddly allen key. Allen key is also likely to bend or snap too.
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post Mar 5, 2006 - 2:19 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
tried that... it was all so rusted together we just sawzalled 'em both. actually, we just finished the left rear... jim's putting the brakes back on and we should be ready to start on the front (****) in a couple minutes.
celicas are bull****, i can't believe what a pain in the ass you guys go through for any little thing on these.. i'll stick to my 240sx tongue.gif
-not user
post Mar 6, 2006 - 2:12 AM
azian_advanced
Joined Apr 18, '05
From Calgary
i'm telling you... you should torch it.. it worked on my 5th gen and it was rusted like hell. no matter how much torque you give it, the hex in the middle get ruined from too much torque.
post Mar 6, 2006 - 2:24 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
QUOTE(azian_advanced @ Mar 6, 2006 - 1:12 AM) [snapback]403218[/snapback]
This post has been edited by jayi12-15psi: Mar 6, 2006 - 2:26 AM
Lo-Fi Version Time is now: August 28th, 2026 - 6:15 AM
