> power antenna wires, help me locate them
post Mar 26, 2006 - 2:34 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
hi all,
im doin a trunk popper mod following batman's how-to...but i was trying to look for the power antenna (cont. power) wire...what color is it?...where is it?....AHHHHHH...im so pissed off..can some1 help plz?????
Replies (1 - 4)
post Mar 26, 2006 - 1:54 PM
94GT
Joined Feb 25, '04
From Fairfield, CA
Remove all of the plastic trim from your trunk. Locate the hole on the left side of the trunk that leads to the power antenna. I can't remember if you can unplug the harness while the antenna is still installed or not, but in any case, unplug the harness by whatever means necessary. Use a multimeter, and with the ignition off and the key out of the ignition ground the black multimeter wire to the body of the car and with the red wire, test each wire to see which one gives a constant supply of 12v. I don't remember what color the supply wire is, but it should be a thicker gauge wire than the rest if I remember right. Good luck! All of the other wires are 12v signal wires (not designed to power anything) so make sure you don't accidentally tap off one of those. That's why it's important to have the key off, because with it on, there will be mutiple wires supplying 12v and you want just the supply wire.
post Mar 27, 2006 - 1:27 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
thanx i found it...but its sucha big risk to splice it up n hook anohter wire to a 30a relay...*sigh*
still cant get it to work......
post Mar 27, 2006 - 9:31 AM
94GT
Joined Feb 25, '04
From Fairfield, CA
As long as you don't pop the trunk at the same time that the antenna is going up and down it probably is no big deal to splice it. I'm not sure what the amp draw is for your trunk popper, though.
post Mar 27, 2006 - 11:19 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
thanx bro for all ur help..I'VE got it to work!!!..BUt i opted to jus route teh wires straight to the battery +....i dont wanna splice them tiny wires .. biggrin.gif
Lo-Fi Version Time is now: August 22nd, 2026 - 6:09 PM
