Mar 27, 2006 - 7:38 PM
Enthusiast ![]() ![]() ![]() Joined Mar 20, '04 Currently Offline Reputation: 3 (100%) |
like the title saids how do i tak off the pin stripes on the side of the car. thanks in advance.
Mar 27, 2006 - 8:07 PM
Enthusiast ![]() ![]() ![]() Joined Aug 20, '03 From Kansas City Currently Offline Reputation: 0 (0%) |
Just like any other sticker...a hot air dryer or a heat gun will do the trick with some dental floss or fishing line. How old is your car? You may have a fade line where the pinstripe was before. Also, sometimes you can peel it off if it's hot enough.
Mar 27, 2006 - 8:27 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 14, '03 From Long Island, N.Y. Currently Offline Reputation: 1 (100%) |
QUOTE(Verde97 @ Mar 27, 2006 - 8:07 PM) [snapback]414128[/snapback] Just like any other sticker...a hot air dryer or a heat gun will do the trick with some dental floss or fishing line. How old is your car? You may have a fade line where the pinstripe was before. Also, sometimes you can peel it off if it's hot enough. yea you're definitely gonna see a fade line |
Mar 27, 2006 - 8:32 PM
It's really hard to tell if he's going to have one or not. When I took off my badges on my 97 with 150K at the time with it always being an outside car, I didn't have any fading at all.
Mar 27, 2006 - 9:34 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 25, '05 From Fort Wayne, IN Currently Offline Reputation: 14 (100%) |
Having recently done this myself, prepare to put more work into it than initial glance.
Start by peeling what you can off of the car. If you're lucky, it will all come off with no problem. If glue residue sticks, use 3M Adhesive remover on it and slowly work your way down the line. Once all the residue is off, claybar the areas where the pinstripe was (and entire car if you're got time) and finish with a nice coat of wax. -------------------- |
Mar 27, 2006 - 9:38 PM
![]() Enthusiast ![]() ![]() Joined Apr 23, '04 From WA Currently Offline Reputation: 3 (100%) |
Where did you get the 3M Adhesive remover from?
Mar 27, 2006 - 9:50 PM
QUOTE(djspike @ Mar 27, 2006 - 9:38 PM) [snapback]414226[/snapback] Where did you get the 3M Adhesive remover from? Wal-Mart. Cost about $4.00. -------------------- |
Mar 27, 2006 - 11:49 PM
pics??...i had these ruberized..i guess you could call em pin stripes/bump gaurds...i peeled em back and there was no fading or difference in paint..it took me 40 min to do thouse, and the badges on the back of the car. I used a flat scrapper wrapped in duct tape and bug and tar remover..worked like a charm..just messy.
Mar 28, 2006 - 10:24 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) |
Mar 28, 2006 - 11:39 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 Currently Offline Reputation: 0 (0%) |
QUOTE(bufferdan @ Mar 28, 2006 - 7:24 AM) [snapback]414548[/snapback] Man I wish I had that when I removed the pinstripping off my old CRX, I remember it took forever... and I broke a couple fingernails. |
Mar 28, 2006 - 11:59 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
QUOTE(bufferdan @ Mar 28, 2006 - 10:24 AM) [snapback]414548[/snapback] does that work for removing emblems/badges too? -------------------- |
Mar 28, 2006 - 12:01 PM
if ur gonna remove your badges, do it by hand..use what i used and maybe a peice of soft wood..its good to get that hard goup off.
Mar 28, 2006 - 12:16 PM
QUOTE(Valo666 @ Mar 28, 2006 - 12:01 PM) [snapback]414585[/snapback] if ur gonna remove your badges, do it by hand..use what i used and maybe a peice of soft wood..its good to get that hard goup off. yea... i did it by hand... was just wondering if that works since it seems easier and less messy -------------------- |
Mar 28, 2006 - 6:00 PM
thanks for all the info guys hope theres no fade marks
Mar 28, 2006 - 10:55 PM
Enthusiast ![]() Joined Feb 21, '06 From MD/NY Currently Offline Reputation: 0 (0%) |
QUOTE(Chanh55 @ Mar 28, 2006 - 11:39 AM) [snapback]414576[/snapback] QUOTE(bufferdan @ Mar 28, 2006 - 7:24 AM) [snapback]414548[/snapback] Man I wish I had that when I removed the pinstripping off my old CRX, I remember it took forever... and I broke a couple fingernails. ya i had a ton of blue tape jammed into my fingernails by the time i was done... what a bad idea that was to do in winter the glue was really cold and after alil i couldn't feel my hands |
| Lo-Fi Version | Time is now: June 24th, 2026 - 2:04 AM |
