> strarting my ignition, could it be the temperature ?
post Apr 3, 2006 - 6:06 PM
hotgoods23
Joined Dec 29, '05
From houston, texas
quick question my car has a problem starting in the morning. After i get home from work leave it in the garage for about 12 hours until morning time again togo to work i have to mess with turning the key in the ignition about thee times until it fully starts up . now it only does this during morning time when it has'nt been driven; throughout the whole day it works perfectly fine. so what do you guys think could it be an old alternator needing to be replaced, could it be my ignition wires because it could'nt be my sparkplugs because i changed them out two days ago or could i be running low on antifreeze which is giving me these dry-starts. if you have a suggestion please tell me cuase i sure need it thank you.
Replies (1 - 1)
post Apr 4, 2006 - 1:54 PM
malecrod
Joined May 30, '05
From MN
QUOTE(hotgoods23 @ Apr 3, 2006 - 6:06 PM) [snapback]417376[/snapback]
Hi there, I had similar problem with my 1990 gts. it had problem starting in the mornings but once warmed up and through out the day will start up fine. After changing battery, cold start injector, distributor etc, it turns out to be the STARTER. I will advice you to check your starter. wink.gif
3sgteing.
..burns twice as bright, lasts half as long.
"The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction."
-Allen Ginsberg-
Lo-Fi Version Time is now: August 25th, 2026 - 11:19 AM
