> Wiring, radiator fans
post Apr 22, 2006 - 8:32 AM
lantz2121
Joined Jun 27, '04
From ohio
Why do my fans come on when I turn the key on? 3rd gen int an st. I am sure I will have lots of stupid little questions, but I know you guys could probably point me in the right direction a little faster. thanks lance
Replies (1 - 6)
post Apr 22, 2006 - 2:22 PM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
mine does too...it stays on constantly till i take the key out. it doesnt bother me...should it? i can't see how it could be bad.
in for explaination
edit: where are you in Ohio?
This post has been edited by gtfc115: Apr 22, 2006 - 2:23 PM
post Apr 23, 2006 - 5:50 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
whoever did your wiring probably did it that way on purpose to prevent overheating. the only negative i see to that is that you don't need the fan unless you are not moving, thus when you are on the freeway it is taking electricity. but i don't think you should worry about it.
post Apr 23, 2006 - 11:11 AM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
could just wire up a switch if it bothers you...im too lazy
post Apr 23, 2006 - 11:28 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
mine does the same thing
post Apr 23, 2006 - 1:30 PM
there is a temp sensor on the radiator that controls when the fans come on. if you dont have the sensor connected, the fans stay on all the time. plug in the sensor and the problem will go away.
post Apr 23, 2006 - 2:54 PM
lantz2121
Joined Jun 27, '04
From ohio
QUOTE(lagos @ Apr 23, 2006 - 6:30 PM) [snapback]425165[/snapback]
The sensor is pluged in.. must mean that it is bad. thanks lance
Lo-Fi Version Time is now: August 28th, 2026 - 8:49 AM
