> boost gauge hook up
post Apr 23, 2006 - 9:37 PM
trd94
Joined Jan 9, '05
From green springs ohio
this is a stupid question but where is the best place to hook up the boost gauge line for a very good psi reading not a vaccume reading any pic would be great
Replies (1 - 5)
post Apr 23, 2006 - 9:39 PM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
mine is T'd into the line that goes to my BOV. lots of people say that the capped ports on the back of the intake manifold work well too.
post Apr 23, 2006 - 9:59 PM
trd94
Joined Jan 9, '05
QUOTE(gtfc115 @ Apr 23, 2006 - 9:39 PM) [snapback]425419[/snapback]
that is where i have mine but i dont get a + psi reading i get a - vaccume reading ? all i want to know how much + psi my turbo is making i have it set for 7 psi but the most my gauge reads is like 3 psi but i am pretty sure that it is pushing more than that, i taped it to the wastegate line and it read around 5-6 psi should i leave it hooked up there or just leave it on the bov line kindasad.gif
post Apr 24, 2006 - 6:54 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(trd94 @ Apr 23, 2006 - 7:59 PM) [snapback]425435[/snapback]
You want to see how much boost is actually making it to the motor - that's what a boost gauge is for... So, it should come from a manifold source. The stock BPV vacuum line is a good source along with the ports on the back of the manifold.
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Apr 25, 2006 - 12:20 AM
trd94
Joined Jan 9, '05
post Apr 25, 2006 - 1:11 PM
Conwa
Joined Nov 5, '05
I also hooked my DV up to the back of my manifold but didnt blow off, i assume that isnt a vacuum outlet then.
Lo-Fi Version Time is now: July 29th, 2026 - 8:13 PM
