> coilovers (Set screws)
post May 6, 2006 - 3:18 PM
celiracer
Joined Oct 5, '05
From NE
I am wanting to get my coilovers put on today, and when i was looking at the how-to i seen you have to grind somthing off. I was wondering if you have to grind that off? I have nothing to use that would grind that off. But please let me know
This post has been edited by celiracer: May 7, 2006 - 7:29 PM
Replies (1 - 17)
post May 6, 2006 - 4:12 PM
deliriouzgtfour
Joined May 15, '03
From So Cal,CA
you can also use a hand saw to saw off the edges as much as possible. then round off the edges ...it works...and its much safer...just make sure u dont put to much friction on it.
QUOTE(celiracer @ May 6, 2006 - 1:18 PM) [snapback]430856[/snapback]
post May 6, 2006 - 4:35 PM
take a hammer and CAREFULLY tap the piece down to turn it into an umbrella shape it will work fine...just be vary vary careful not to hit the shaft
post May 6, 2006 - 7:30 PM
celiracer
Joined Oct 5, '05
From NE
well my sway bar end link is kinda screwy i went to loosen it and it budged loose. And i went to take it all the way off and it just sits there and spun.. I took an allen wrench and a plyers and got it all the way tightend again but i think i need to buy a new one. you think i would be ok driving the car?
post May 7, 2006 - 2:14 AM
did you use an allen wrench while removing the link?
cause that sounds like you just tried to use a wrench only
post May 7, 2006 - 2:25 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
make sure u put some kinda "washers" between the threaded sleeve n shock body....a 3/4" heater hose works fine wink.gif
post May 7, 2006 - 2:27 AM
celiracer
Joined Oct 5, '05
From NE
Got everything under control lol. decided to wait till monday, so my dad can help me to it. and get an alignment right away. will post up pics as soon as its done wink.gif
post May 7, 2006 - 7:32 PM
celiracer
Joined Oct 5, '05
From NE
Dew Hoe. are you talking about a type of thing to put on the bottom part of the coilovers that goes inbetween that and the holder of the strut? If so what all could i use for a washer?
Does anyone know where i can get more set screws? I'm missing 6 of them.
I would also like to know where i can get the rubber washer type things that set on the strut housing.
This post has been edited by celiracer: May 7, 2006 - 7:48 PM
post May 7, 2006 - 8:29 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
heater hose (3/4") works wodners between the sleeve n strut body....one on top of the sleeve n bottom
for other acc....try checkin with ground control..they might have it.....
This post has been edited by DeW_H0e_GT: May 7, 2006 - 8:31 PM
post May 7, 2006 - 8:37 PM
celiracer
Joined Oct 5, '05
From NE
Do you have any pics showing where them spacer things go? do they go inside the sleeve? or just set ontop of them? Also are they just like rubber o-rings?
post May 7, 2006 - 8:56 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
sorry i dont have any pics but i do have this website,,,its not for a 6gc but for a miata...but the concepts teh same.....:
http://www.villacorte.com/miata/gc_coilover/
post May 7, 2006 - 9:57 PM
celiracer
Joined Oct 5, '05
From NE
Thanks man i don't know if that helps me tho. I just need to know if they are a type of o'ring or if they are squared on each end so it sets flush on each side?
post May 7, 2006 - 11:09 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
theres suppose to be o rings which replaces the "washers"...but some applications doesnt need it..this is jus a safety precaution n to reduce teh chances the coilovers bangin against the shock body....hope this helps frown.gif
post May 8, 2006 - 1:58 AM
celiracer
Joined Oct 5, '05
From NE
Ok, that helps me. Thanks Dewhoe. I'll have to go look for some o'rings tomorrow and try and find 6 more set screws so i can start on my back two struts tomorrow.
post May 8, 2006 - 10:01 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
for the set screws......bring your locking perch to any hardware store n have them find a allen hex screw for u...i personally would go to advance to have them find out the size n then i would go to home depot n get the screw from them.....jsu a tought biggrin.gif
post May 8, 2006 - 12:16 PM
celiracer
Joined Oct 5, '05
From NE
ok just to make sure i have everything that an actual kit would come with.
4 sleeves
4 caps
4 springs
12 set screws
8 rubber o'rings
2 adjuster tools
Is that everything that a new kit would come with?
Please let me know.
post May 8, 2006 - 2:10 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
yes...some kits have metal washers taht goes on top of the caps...in most cases tehese arent even neccessary...so ur good to go with the described parts....
post May 8, 2006 - 3:54 PM
celiracer
Joined Oct 5, '05
From NE
when i was looking on the aerospeed website there installation guide is way different then our how-to. It shows them o'rings but doesn't say anything about installing them? And i have no idea how big the o'rings have to be and where they go on the installation.
Lo-Fi Version Time is now: September 3rd, 2026 - 3:21 AM
