> Interior Lights All DEAD!, help! (pics added)
post May 7, 2006 - 11:46 AM
fastcelica20
Joined Apr 4, '06
From Minnesota
my gauge cluster isn't working no more. i took out my white face and now the pins wouldn't move? anyone know why? help fast! thanks
This post has been edited by fastcelica20: May 9, 2006 - 7:54 PM
Replies (1 - 19)
post May 7, 2006 - 1:29 PM
team_omega
Joined Aug 14, '05
From St. Paul, MN(USA)
did you check your connector that connects to the cluster???if not that then you might have a bad cluster...if not that then check your speed sensor on your transmission...
post May 7, 2006 - 2:24 PM
fastcelica20
Joined Apr 4, '06
From Minnesota
QUOTE(team_omega @ May 7, 2006 - 1:29 PM) [snapback]431119[/snapback]
i know it can't be my sensor. it was great before i took the white face off. after that it wasn't working. i went and got new fuse 7.5 and intalled and the rev meter and the oil/temp started to work. but the speedo didn't work. im very pissed. could it be anything else? the connector is good. can't be a bad cluster i tell ya
post May 7, 2006 - 9:59 PM
fastcelica20
Joined Apr 4, '06
From Minnesota
good news and bad news. i fixed it but now the interior lights are dead! i replaced it but no work! anyone plz help me!!!!!!!!!!!!!!!!!!!!!!! this is the worst day of my life!!!!!!!!!!!im stuck in the dark the only thing that lights up are my cd player and my dvd dash in my car. crap someone help! my car is dying,,,
post May 7, 2006 - 10:56 PM
make sure the dimmer switch is plugged in properly.
post May 8, 2006 - 8:10 AM
fastcelica20
Joined Apr 4, '06
From Minnesota
QUOTE(Batman722 @ May 7, 2006 - 10:56 PM) [snapback]431339[/snapback]
where is the dimmer switch located? ill try to change the fuse also. i think fuse #10a
post May 9, 2006 - 11:42 AM
fastcelica20
Joined Apr 4, '06
From Minnesota
mornin' bump
no one knows?
post May 9, 2006 - 12:39 PM
sorry, the dimmer switch is located to the left of the steering wheel. It is a round knob.
post May 9, 2006 - 3:26 PM
fastcelica20
Joined Apr 4, '06
From Minnesota
tried that didn't work. could it be my fuse then?
post May 9, 2006 - 4:28 PM
massbrandon
Joined Mar 6, '06
From massachusetts
QUOTE(fastcelica20 @ May 9, 2006 - 4:26 PM) [snapback]432029[/snapback]
I had the same problem. I checked all of my interior fuses and changed a couple of them, that worked. Hope that helps.
Dont forget to check the ones under the hood.
This post has been edited by massbrandon: May 9, 2006 - 4:29 PM
post May 9, 2006 - 5:28 PM
fastcelica20
Joined Apr 4, '06
From Minnesota
well i shouldn't be checking the ones on my hood cause they're lil' different. i checked the one under my steering wheel and checked "gauge" light. i think i might have to change the 10a fuse because when my previous owner put in the indiglo gauge, she put the red wire in the fuse. kinda confusing but yeah that's how it was pulled out. i think its bad. ill change and tell you guys if its the fuse or not. thanks batman and massbrandon.
post May 9, 2006 - 7:53 PM
fastcelica20
Joined Apr 4, '06
From Minnesota
ok i found something weird. here are some pics:
here's the problem. i found two similar wires. the two that has the white swirlies. what's the other one for? one is fat and one is skinny and long. batman/coomer/people help! i drove in the dark yesterday from school and was scared to death. no interior lights at all. that was the only car i have.
btw, yesterday was raining like crazy even my wipers couldn't help me on the highway frown.gif
This post has been edited by fastcelica20: May 9, 2006 - 8:05 PM
post May 9, 2006 - 8:54 PM
TheStreetzKing
Joined Jun 19, '05
u check fuses??
post May 9, 2006 - 9:03 PM
fastcelica20
Joined Apr 4, '06
From Minnesota
QUOTE(TheStreetzKing @ May 9, 2006 - 8:54 PM) [snapback]432175[/snapback]
u check fuses??
yup. i replaced the red ones which are the 10a and also replaced the 7.5a fuses. nothin lit up? the red ones are mostly for the interior lights such as gauge lights and heater lights and such. now i dont know what else to do? does the relays have anything to do with it?
post May 9, 2006 - 9:13 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
look for the "DOME" fuse under the hood.
post May 9, 2006 - 9:20 PM
fastcelica20
Joined Apr 4, '06
From Minnesota
i replaced that. here's the problem. i have a 95 and my motor is a 96+ with the 5 extra hp. is that the problem then? im so so so so so so so so confused guys. kindasad.gif
post May 10, 2006 - 12:13 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
ok yeah i had that problem once when i install my ground kit...the whole interior gauges didn't work at all..check the fuse box under the hood..check the main fuses..the fuses that you have to remove srews and stuff..i woul dcheck mine but its like 12 midnight...
post May 12, 2006 - 8:45 AM
fastcelica20
Joined Apr 4, '06
From Minnesota
ok i put in my white gauge face back in. the lights are working again. now im really confused cause it can't be the fuse. must be some sort of wire problem. but oh gosh this is killing me.
post May 13, 2006 - 12:56 AM
Zimluura
Joined Feb 3, '05
From USA/Virginia
so these white gauge faces are just pieces of plastic, right? nothing else to them like indiglo or anything?
also do/did the climate control and cigarette lighter light up?
if you're going to spend a bit of time troubleshooting this then you might want a temporary work-around. maybe duct tape some keychain leds to the steering column to illuminate the gauges while you're trying to get things to where you want them.
post May 13, 2006 - 12:56 PM
Niskyspy
Joined Jan 21, '05
From NY
There is one more thing that might be wrong.
Check out whats up with ur gauge dimming thing (its a knob that regulates how bring ur interior lights are) if its disconected or brken all the interior lights will be off.
<<AKA THA RUSSIAN>>
Lo-Fi Version Time is now: August 31st, 2026 - 4:43 AM
