> need help with pb gun
post May 7, 2006 - 4:15 PM
94_st_hatchback
Joined Mar 15, '06
From Long Beach
hey guys...i juss went outside to shoot out the rest of my pb's but something happended when i hooked up my co2...when i had it on safe it was ok, i could dry fire..but when i took safe off the thing went nuts on me..started shooting by itself like crazy!!!
any ideas...is it my gun or what??
" i don't work for toyota, i work for my toyota. "
Replies (1 - 7)
post May 7, 2006 - 4:25 PM
Its possible that your bottle was close to empty, I've had it happen before.
post May 7, 2006 - 6:55 PM
94_st_hatchback
Joined Mar 15, '06
From Long Beach
QUOTE(Supersprynt @ May 7, 2006 - 4:25 PM) [snapback]431169[/snapback]
how do i know if my bottle is empty or not??...do the gauges tell you what pressure its on or what??
post May 7, 2006 - 7:01 PM
well you could put it on the gun and try to fire it. Thats probably the easiest way.
Did it shoot on its own and then kinda die out?
post May 7, 2006 - 8:25 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
if its one of the full auto ones, your electronics could be bunk.....friend had an older E99 ( i dont stay with pb so idk where the E99 ranks now) but he got it right when it came out, and he would pull the trigger on full auto, hold...release.....and it would keep shooting till he pulled the trigger again. Ended up being someting with the trigger. it would get stuck or something.
Kawi Love
post May 8, 2006 - 2:11 AM
Predator
Joined Feb 26, '05
From Sweden
do you mean that it didn't recock after you shot, it just kept shooting? itf so you're prolly either low on gas, got a busted o-ring on the bolt or your velocity adjuster is set too low
post May 8, 2006 - 9:43 AM
b1gr3d
Joined Feb 25, '03
From Springfield, MO
take the tank out ane push on the pin in the moddle of the threaded part. if you can push it at all then it's empty or close to it...use your FINGER nothing else
Coming in 2010
post May 8, 2006 - 10:47 AM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
Most likely low on CO2. If its an actual problem then check the oring on the hammer.
FlickR
Lo-Fi Version Time is now: September 4th, 2026 - 9:18 AM
