> EA1, Location
post May 8, 2006 - 5:32 PM
bigal004321
Joined Jun 21, '05
From New york
Where is the EA1 plug located in the engine bay? Cuz i havent found it yet kindasad.gif
Bigal
PS thanks in advance for the help
1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
Replies (1 - 8)
post May 8, 2006 - 7:17 PM
its under the square part of the fuse box in the engine bay
post May 8, 2006 - 8:36 PM
Its the big one in the fuse box. Remove the fuse box and its the one that plugs into the bottom.
post May 9, 2006 - 1:07 AM
bigal004321
Joined Jun 21, '05
From New york
The main relay box that is on the driver side of the engine bay?
IPB Image (like this relay box)
IPB Image ( or this one)
post May 9, 2006 - 6:22 AM
the first pic under the section that says "relay& fuse"
once you remove the cover and have a look, youll see that the "square" section of the fusebox is removeable, once you lift it, EA1 is under that.
post May 9, 2006 - 8:48 AM
Outsider
From Kelowna, BC
As Pressure2 says, it's under your main fuse box in the engine bay. The fuse box has plastic clips on each side that lock the top and bottom sections together. Once you unlock these clips(not hard) the top of the outer casing will lift off. You will now have access to the fusebox wiring.
1994 GT-S (BEAMS) swap complete
post Oct 5, 2009 - 3:13 PM
wow, bringing from the dead, but could not find a pic
which one is it
Im assuming is this one right?
or this one
post Oct 5, 2009 - 4:15 PM
QUOTE (njccmd2002 @ Oct 5, 2009 - 3:13 PM) *
which one is it
or this one
the first pic.
post Oct 5, 2009 - 6:35 PM
thanks
Lo-Fi Version Time is now: July 8th, 2026 - 6:07 AM
