> Tercel w/ 4efte, motor swap
post May 16, 2006 - 7:24 PM
o8poa8o
Joined Jun 11, '04
From Wake Forest, NC
Wow i dont think i've been on here in like a year! But I read about a Tercel with a 4efte (JDM Starlet Motor 135hp Turbo) with 175hp with just bolt on's (intake exhaust, intercooler, piping, turbo timer, boost controller), and he had a stage 2 clutch, light weight fly wheel, and 15's wheels with drag radials wrapped around them, and he was running in the high 13's!! And apartently the 4efte is direct bolt in motor (same mounts).
Anyways i thought it was pretty neat. Nearly 2000lb car. Car is like $1500-2000 for a early 90's, you can get the motor imported for around $1200, and some good tire/wheels and a few bolt on's it'll be in the 13's!
Just thought you guys might be interested in hearing about it, i hadn't really ever noticed the tercel before i read about this one.
Replies (1 - 4)
post May 16, 2006 - 9:09 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
http://www.phoenixtuning.com/toyota/swaps/4eftetercel.html
That's one that I did. Definetely a cool swap.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post May 17, 2006 - 10:02 PM
o8poa8o
Joined Jun 11, '04
Thats pretty neat. Do you know what mod's they are doing to it (or your installing for them!).
post May 19, 2006 - 8:53 PM
jdg371
Joined Jun 14, '05
Swapped Tercels can be pretty fast.. from I believe the fastest one is in TercelOnline.com ... its a 80s model Tercel with a 400Hp 4AGTE
But 13's would actually take more than the normal upgrade.. The CT9 dies at around 12 psi. I think a turbo upgade is necessary to get into 13's. And an awesome launch
post May 29, 2006 - 12:33 AM
celicurr
Joined Jan 29, '06
From Kitchener, ON, CA
QUOTE(Dr_Tweak @ May 16, 2006 - 9:09 PM) [snapback]434754[/snapback]
-Doc
wow Tweak!! what haven't you done!
Lo-Fi Version Time is now: August 24th, 2026 - 5:21 PM
