> Got My 3" exhaust!!!, Wow
post May 20, 2006 - 10:29 AM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
So I finally got my exhaust done. It's such a HUGE difference...I had no idea. my old exhaust had so many leaks, was crush bent, and was only 2 inches...if that. now it sounds so much better, not too loud and has a great low growl to it. Im boosting ~13psi now. kinda scary at times.
now my mods list includes: (92 JDM Mr2)
MBC (@13psi)
Walbro 255lph
ACT Stage 2 clutch w/ fidanza flywheel
Full 3" exhaust!!!
Also, Im pretty sure I hit fuel cut a few times, but i have the vac hose plugged going from the turbo to the t-vsv so I shouldnt have fuel cut should I? maybe im misunderstanding something about how it works. i have an hks FCD but its not installed because since my harness had been re-wired twice, i cant tell which wire i need to splice...is there a link to the pinouts for the 92 jdm mr2 ecu somewhere?
comments? suggestions for my next mod? i'll have a chance to get it dyno tuned at a place in Columbus in the next few weeks. any idea how much power i should have at the wheels with these mods?
Replies (1 - 14)
post May 20, 2006 - 10:54 AM
Rjb23
Joined Feb 8, '04
From KY
That doesn't effect fuel cut. Your fuel cut is still at 12psi you have to raise your fuel cut to change it.
post May 20, 2006 - 11:00 AM
take the vac line that goes to the map sensor (turbo presure sensor), disconnect and cap oof the 2 ends. you will have no fuel cut. just keep an eye on your boost gauge.
3in exhaust is a must for any turbo car. i love mine.
what muffler did you go with for your exhaust?
This post has been edited by lagos: May 20, 2006 - 11:01 AM
post May 20, 2006 - 11:30 AM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
i stuck with the same Ractive muffler that i already had because it always had the best sound out of most others that ive heard.
i'll probably just turn the boost back down a little till i can get it tuned. there arent many dyno's around here so i'll make due with 11 or 12 psi...plenty.
post May 20, 2006 - 12:34 PM
burneeed
Joined Dec 18, '05
From BANNED
do you have a downpipe comming fromt he turbo or is that first cat still there?
BANNED!
post May 20, 2006 - 12:37 PM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
QUOTE(burneeed @ May 20, 2006 - 5:34 PM) [snapback]436026[/snapback]
oh, yeah that first cat is still there...so i guess its not a FULL 3". What downpipes are you guys using?
post May 20, 2006 - 12:38 PM
if you have your old muffler.....isint the muffler smaller then 3in causing a bottole neck?
get a full 3in magnaflow. i love mine and since i got it done, everyone always says how great the car sounds!
post May 20, 2006 - 12:49 PM
burneeed
Joined Dec 18, '05
From BANNED
Magnaflow or Top speed FTW!
BANNED!
post May 20, 2006 - 1:54 PM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
QUOTE(lagos @ May 20, 2006 - 5:38 PM) [snapback]436029[/snapback]
yeah its probably a minor bottleneck..the inlet isnt quite 3" but its still bigger than the rest of my old exhaust. i'll look into the magnaflow.
post May 21, 2006 - 12:11 AM
trd94
Joined Jan 9, '05
From green springs ohio
QUOTE(gtfc115 @ May 20, 2006 - 11:30 AM) [snapback]436008[/snapback]
hey man i did not know there was another turbo celica in the north west ohio area biggrin.gif that is awesome , if your looking for dynos there are two in the norwalk area crt performance, and bushurs racing, i am heading to bushurs in a few weeks or so if you want i will let you know how it goes wink.gif
post May 21, 2006 - 10:03 AM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
QUOTE(trd94 @ May 21, 2006 - 5:11 AM) [snapback]436169[/snapback]
yeah there are a couple 3s swaps here in toledo...mine and another in a 5th gen. let me know how you do on the dyno. i was gona turbo my 7a before i did the swap, but never went through with it. i'd like to see what kinda numbers i coulda have put down.
post May 21, 2006 - 1:20 PM
trd94
Joined Jan 9, '05
QUOTE(gtfc115 @ May 21, 2006 - 10:03 AM) [snapback]436234[/snapback]
i will let you know, wink.gif who did your swap for you anyone in the area , thinking about swapping in the future
post May 21, 2006 - 2:19 PM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
QUOTE(trd94 @ May 21, 2006 - 6:20 PM) [snapback]436300[/snapback]
most of it was done by a small non-tuner auto repair shop...the had no experience with it, but stuck with it and did a good job IMO. some of the work was also done at a place called Gearheadz...overpriced to say the least.
anyways, if/when you're ready to do the swap, they're in Perrysburg called Express Auto. Great guys, and now they have experience with the swap after troubleshooting mine for 2 years
post May 22, 2006 - 7:45 AM
trd94
Joined Jan 9, '05
QUOTE(gtfc115 @ May 21, 2006 - 2:19 PM) [snapback]436328[/snapback]
awesome !! thanks for the info
post May 22, 2006 - 8:41 AM
94wrc
Joined Mar 24, '06
From Slough,Berkshire,UK
I take it that none of you guys that have done the 3s-GTE swap suffer from boost creep with the 3" exhausts? in the UK if we use the standard ct20 on a 3" system we normally get boost creep, it might be down to us having 99 ron fuel. It happened to me the other day and went up to 21.4 PSI then I hit fuel cut and spat a big flame out of the back smile.gif I think the 2 solutions to this problem is either to fit an external wastegate or a restrictor plate in the exhaust to increase backpressure slightly so the wastegate can work better.
Nathan
1994 JDM ST205 WRC with 17" OZ Chrono's wearing 215/45/17 Eagle F1's. HKS Induction Kit, Blitz DV, Decat and full SS System, Blitz SBC-iD and Power Meter running at 1.12Bar = 17mpg and a lot of fun
Lo-Fi Version Time is now: July 28th, 2026 - 5:33 PM
