May 21, 2006 - 10:29 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Hollywood, FL Currently Offline Reputation: 0 (0%) |
well I need to cut some plastic, I want to test out something and write my name in cursive in the plastic. What would be the easiest way to give it a nice clean look. Oh, and the pastic is about as hard as the door stops on our car.
-------------------- To live, is to suffer
To survive, thats to find meaning, in the suffering.... ![]() |
May 21, 2006 - 10:33 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
i was gonna say dremel tool....but the door stops are more rubbery then plastic.
if its hard/ridged, a dremel tool would work best. if its rubbery...idk -------------------- ![]() Kawi Love |
May 22, 2006 - 5:28 AM
Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Hull, UK Currently Offline Reputation: 0 (0%) |
You could try a knife attachment on a soldering iron?
How thick is the plastic mate? Might be worth looking for a company that would laser cut it for you, then it would be a perfect finish. |
May 22, 2006 - 6:55 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
Scroll Saw
May 22, 2006 - 8:53 AM
the plastic is about 1/10th an inch think, the only reason I dont wanna use a dremel is because it will melt and cut the plastic and give an unsmooth finish. I was hopin there was a special knife or somethin used for cutting plastic.
May 22, 2006 - 8:57 AM
Enthusiast ![]() Joined Mar 24, '06 From Slough,Berkshire,UK Currently Offline Reputation: 0 (0%) |
Maybe if you use some sort of scalpal (?SP?) or craft knife.
Nathan -------------------- 1994 JDM ST205 WRC with 17" OZ Chrono's wearing 215/45/17 Eagle F1's. HKS Induction Kit, Blitz DV, Decat and full SS System, Blitz SBC-iD and Power Meter running at 1.12Bar = 17mpg and a lot of fun
May 22, 2006 - 8:58 AM
You could use a dremmel to remove most of the material and then use your soldering iron knife to slightly melt the cut rough edge into a smooth edge if sanding is too difficult.
Not sure how you could do it, but a hot piece of wire might cut a nice edge? Maybe pass a current through a piece of fuse wire and see if it does anything? Thats only a maybe, don't go electrocuting yourself dude. |
May 22, 2006 - 9:07 AM
QUOTE(94wrc @ May 22, 2006 - 2:57 PM) [snapback]436585[/snapback] Maybe if you use some sort of scalpal (?SP?) or craft knife. Nathan Doubt that would work mate, it sounds about 2 - 3mm thick so it would be very difficult to cut with a knife, unless he can use a blowtorch or something to heat the blade? |
| Lo-Fi Version | Time is now: August 24th, 2026 - 2:40 PM |
