May 22, 2006 - 9:42 AM
Enthusiast ![]() Joined Jan 18, '06 From St.lucia Currently Offline Reputation: 0 (0%) |
hey guys my car refusing to boost to 10 psi then i get a feul cut
May 22, 2006 - 11:11 AM
You probably have a boost leak. Check all your connections for loose fittings or cracked hoses.
May 22, 2006 - 7:31 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) |
what size is your exhaust pipe size and your down pipe , before i got my 2 1/2 exhaust pipe done i was using the factory pipe and i could not boost any more than 5 psi , now i have 3 in down pipe and a 2 1/2 exhaust pipe all the way back ,i also got rid of all the cats and pre mufflers , i run two high flow cats at 3" in and out also i ran the exhaust under the axle not over it the less bend the more flow ,better boost . i am boosting at 7psi every day and when i want to really run her hard i take it to 10psi for know
This post has been edited by trd94: May 22, 2006 - 7:35 PM -------------------- ![]() |
May 22, 2006 - 10:32 PM
kool thanx man but i have a 3" exhaust all the way back ... but i think it has something to with a tapping noise i am hearing the number 4 cylinder area
May 22, 2006 - 10:42 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
i doubt that the exhaust size is the problem. you probably either have a boostleak or there is something wrong with your wastegate.
May 22, 2006 - 11:25 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
Check engine light on ?
-------------------- ![]() I will return one day. |
May 23, 2006 - 8:21 PM
Enthusiast ![]() ![]() ![]() Joined Dec 18, '05 From BANNED Currently Offline Reputation: 0 (0%) |
if its not boosting to 10psi then I would put money on tvsv... did you recently do the swap or try to add a boost controller?
-------------------- BANNED!
May 23, 2006 - 8:50 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
I say boost leak FTW. If not, then like he said...TVSV!
| Lo-Fi Version | Time is now: July 29th, 2026 - 5:42 AM |
