> axle install, got any tips?
post May 22, 2006 - 3:58 PM
Willy2o9
Joined Oct 6, '05
so, im probably not a great mechanic but i was able to pull my axle , basically the snap ring wasent locked into place when my stepdad refurbished my old axle(hes a mechanic lol)... so i took matters into my own hands and removed the broken axle, tomorrow my new axle will be here... i got the putting it back in down,
my question is.
any tips or things i need to do before i install the new axle?
do i need to grease/lube any thing?
thanks in advance
Willy
Willy //2o9// California
Replies (1 - 6)
post May 22, 2006 - 8:54 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Put some grease around the part of the axle that goes into the tranny so that it doesn't damage the seal, other than that, make sure the snap ring snaps into place... and remember to refill the tranny afterwards smile.gif
Have fun.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post May 23, 2006 - 8:20 PM
Willy2o9
Joined Oct 6, '05
QUOTE(Dr_Tweak @ May 22, 2006 - 8:54 PM) [snapback]436838[/snapback]
Have fun.
-Doc
hey doc, im having some trouble getting the axle to go in, it goes in like an 8th of inch and stops, it will not go in any further
its my driverside axle, im stuck ive been at this for like 5 hours, can u help me out?
is their a trick to making it go in the rest of the way?
post May 23, 2006 - 9:36 PM
it can be tough getting it seated properly, it took a few trys and patience with mine. Just pull it back out a bit and bang that bastard in.
post May 23, 2006 - 11:56 PM
all you have to do is line it up by hand as best as you can. then you take a long flat head screw driver and a hammer and tap each side of the axel in.
post May 24, 2006 - 6:43 PM
Willy2o9
Joined Oct 6, '05
so... i installed the axle, and it popped back out on the test drive, then the lugnut bolt broke off... so im 1 lug short... i hate my car
post May 24, 2006 - 6:57 PM
if the axle popped out then it wasnt in all the way, you'll feel it go CLACK when it snaps into place. get a brass hammer or a peice of wood and hold against the axlenut end of the axle and give it a good smack or 2 to knock it into place. i know my passenger side was difficult to snap in. if not, then try what lagos said, but try using a pry bar since it'll be longer and easier to hit.
Lo-Fi Version Time is now: September 13th, 2026 - 6:52 PM
