> Who has replaced wheel bearings?, Scraping noise, need some advice.
post Jun 14, 2006 - 5:29 PM
DomGT
Joined Apr 19, '06
From Long Island, NY
I have what sounds like metal-on-metal contact when I make right hand turns. This noise has progressively gotten worse. Now I can hear the noise on bumps and even light turns. Anyone have advice or info for me?
edit: These cars handle REALLY well. Good steering system and 2400 lbs makes my car handle like a brand new Acura RSX! I can tell you this, my 143k mile 6GC handles MUCH BETTER than my '99 twin turbo 3000GT VR-4! The VR-4 is AWD too.
This post has been edited by DomGT: Jun 14, 2006 - 5:31 PM
'92 Grey Mitsubishi 3000GT SL - Sold
'96 Black Celica ST 25th Anniversary - Sold
'99 Black Mitsubishi 3000GT VR-4 - Sold
'04 E250 Work Van - Going soon
'08 Grey Dodge Charger Work Car - Ordered
Replies (1 - 19)
post Jun 14, 2006 - 5:44 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
sounds like cv joints or the axle
post Jun 14, 2006 - 6:59 PM
done any work in that area recently? could be a brake dust sheild rubbing against the rotor.
post Jun 15, 2006 - 12:17 AM
DomGT
Joined Apr 19, '06
Guys thanks a lot for the comments, I haven't done any work around there... but I'm going to check it out this weekend and I'll post my results.
post Jun 15, 2006 - 8:54 PM
cheeco
Joined Jun 15, '06
From NJ
i have replaced front wheel bearings, on a GT. but im pretty sure its the same
in the ST. biggest deal is having access to a press, oh and while it may cost around
$100 its a good idea to replace the hub while your at it. dont do like i did and press
a worn out hub into a brand new bearing :x
post Jun 16, 2006 - 12:19 AM
purplegt4
Joined Feb 7, '03
From Northern Virginia
QUOTE(DomGT @ Jun 14, 2006 - 6:29 PM) [snapback]444668[/snapback]
metal-on-metal contact...progressively gotten worse.
definitely wheel bearing. it'll make you feel so much better when u get it replaced.
post Jun 16, 2006 - 3:40 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Lift the car and wiggle the wheels... then actually LOOK at the CV's... =P
post Jun 17, 2006 - 11:22 PM
LewFX
Joined Jan 28, '05
soooo was Kwanza and I right?
post Jun 18, 2006 - 11:47 AM
DomGT
Joined Apr 19, '06
Getting a new hub, bearing and brake lines installed. smile.gif Yes I cringe at every right-hand turn over 20MPH.
post Jun 18, 2006 - 4:12 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
I replaced my driver's side one already and am getting read to replace the passenger side smile.gif
post Jun 18, 2006 - 5:49 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
I replaced my driver side too.. it was pretty bad. The easiest way to check, like someone said, is to lift the car and wiggle the wheel. side to side top to bottom. Id pull it yourself and take it somewhere.. It will be much cheaper than just having someone do it.
Also, why are our cars infamous for wheel bearings going out?
post Jun 19, 2006 - 1:58 PM
scothaniel
Joined May 1, '03
From Michigan
All cars wear out thier well bearings, just basic maintenance. I've replaced the bearings in both of my Celica's, a Maxima, a DSM and a 4 runner in the past 5 years.
So it was only happening on turns? That doesn't sound like a wheel bearing - wheel bearings are usually a constant noise. The fact that its happening on turns sounds more like CV or tie rod end.
A worn tie rod or control arm busing would also allow the wheel to wiggle, so be sure to keep an eye on those parts when doing the wiggle test mentioned above.
This post has been edited by scothaniel: Jun 19, 2006 - 2:01 PM
Scott
West Michigan
post Jun 19, 2006 - 2:45 PM
LewFX
Joined Jan 28, '05
extra wheel bearing grease helps keep the bearings lubed up
post Jun 23, 2006 - 2:28 PM
Celicaguy13
Joined Sep 9, '05
From Modesto, CA
When I took off my tire the other day, I was able to wiggle the wheel stubs side to side, up and down real easily with lots of clearance "bad" this is a wheel bearing right?
Also, when I make a tight turn, my steering tends to want to stay in that direction and when i'm driving it's pulling to that side. What would cause this?
post Jun 23, 2006 - 4:14 PM
LewFX
Joined Jan 28, '05
tie rod, axle, bearing all going bad at once?
post Jun 23, 2006 - 4:18 PM
QUOTE(LewFX @ Jun 19, 2006 - 2:45 PM) [snapback]446337[/snapback]
but overpacking them can cause them to overheat, or so ive been taught.
post Jun 23, 2006 - 4:50 PM
LewFX
Joined Jan 28, '05
mine have yet to overheat
post Jun 23, 2006 - 5:32 PM
cheeco
Joined Jun 15, '06
From NJ
sealed bearings are pregreased and dont need grease added, but bitter is right about taper
roller bearings, too much grease is not good. our cars have sealed, pressed bearings.
post Jun 23, 2006 - 5:49 PM
QUOTE(cheeco @ Jun 23, 2006 - 5:32 PM) [snapback]448194[/snapback]
you sure the fronts are sealed units? i replaced my front bearings on a press. the REAR bearings are a hub unit that bolts into the knuckle.
post Jun 23, 2006 - 6:07 PM
LewFX
Joined Jan 28, '05
i was talking about the rears, theres a small opening in the back, i just added a small amount as i turned the bearing to make sure it was well lubed.
Lo-Fi Version Time is now: May 27th, 2026 - 6:20 PM
