Jun 23, 2006 - 6:02 PM
Enthusiast ![]() Joined Jun 15, '06 From NJ Currently Offline Reputation: 1 (100%) |
ok, im doing a 94 GT Coupe 5s-fe auto to 3s-gte swap/conversion. after spending hours upon hours of reading and re-reading everyones great how-tos and other posts, ive come up with a final parts list of stuff i need. please let me know if i should change/add/delete anything. ok here goes:
Stuff i have or have coming. - 96' ST205 front clip - 97' 5s-fe (s54) manual trans, salvage 100k miles, but 6mo garanteed. - slave cylinder (came w/ trans) - shift fork (came with trans) - Spec Stage 2 3s-gte clutch kit w/ 5s hub conversion (thanks justin) - walbro supra 255 fuel pump kit + noise sleeve -Seal + maint - T-belt - Front +Rear seals - cam seal - Intake + valve cover gaskets - fuel +air+oil filters Stuff i need to get - 5s shift cables - 5s manual axles w/ abs (both sides) - 5s clutch hydrolic lines/hoses - 5s axle seals Questions about stuff can i use the st205 clutch/brake pedal and clutch master? can i use the st205 shifter (if its included) should i replace the water pump its like $100 bucks, clip has somthing like 30k on it i ordered mostly usdm seals etc from toyota for the 93 alltrac, that should be ok for the st205, right? should i replace the stock downpipe, i dont really care about the extra weight do the japs use cats? will there possibly be one already attached? if not can anyone suggest where to look for that and a nice NOT LOUD, but nice sounding exhaust. please feel free to throw any input, its much appreciated, thanks This post has been edited by cheeco: Jun 23, 2006 - 6:06 PM |
Jun 24, 2006 - 12:48 PM
QUOTE should i replace the water pump its like $100 bucks, clip has somthing like 30k on it yes. it might have 30k on it, but its still a 10yr old gasket and pump on there. do the timing belt as well QUOTE should i replace the stock downpipe, i dont really care about the extra weight yes, the downpipe is a huge upgrade that you will want. youll kick yourself later on for not doing it while the motor was out. QUOTE do the japs use cats? will there possibly be one already attached? if not can anyone suggest where yes they have cats. there is one inside of the stock downpipe. if you want a good exhaust, get 3in mandrel bent piping and a magnaflow muffler. i love mine, its not to loud or to quiet. sounds like your on the right path and trying to do things correctly . good luck This post has been edited by lagos: Jun 24, 2006 - 12:49 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jun 24, 2006 - 1:28 PM
QUOTE can i use the st205 clutch/brake pedal and clutch master? no as the pedal is for the wrong side of the car you need to find one from a usdm...but i have PM'd you about these pieces and the shifter should be the same no matter wat so the one from the clip should work but the trim peices won't This post has been edited by playr158: Jun 24, 2006 - 1:31 PM |
Jun 24, 2006 - 1:48 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) |
lagos, he already mentioned he was doing a T.belt
as for the parts being ordered as a 93' alltrac for the 96' alltrac. I don't think many people here can give you a 100% guarantee that it will work but most or all of it should work ok. Goodluck with the swap. -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Jun 24, 2006 - 1:53 PM
if its a 3rd gen 3sgte wouldn't it be safer to find parts from a 3rd gen 3s mr2?
Jun 24, 2006 - 1:57 PM
^^^ Yeah I don't think water pump, tbelt, anything like that is different on the mr2s. Good idea.
Jun 24, 2006 - 3:42 PM
thanks everyone for the tips, where can i order parts for a 3rd gen 3s mr2 motor then, didnt they stop making mr2s in in the us in like 95 with the 2nd gen? thanks again
Jun 24, 2006 - 3:59 PM
search on mr2 oc... they have a whole list of 3rd gen part numbers you can use to order stuff from the dealer
Jun 24, 2006 - 4:28 PM
Enthusiast ![]() ![]() ![]() Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
might want to change the dizzy seal & oring aswell...
cap, rotor, OEM wires, plugs, valve cover gasket........were all on my list too.. again, same mind set with that damn downpipe, while its out of the car its 10000 times easier to work with. maybe change the hose from hell too. although i didnt bother with mine.. yet |
Jun 26, 2006 - 4:50 AM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
You should be able to use the clutch master cylinder from the tranny, but you will need the hard lines from a USDM M/T GT Celica, along with the pedal set. The rubber line and stuff on the tranny will work fine for you. Junkyards are your best bet for this stuff...
T-belt is 3rd gen specific, as is the t-stat... and a number of other parts. Look up the stuff on mr2oc under the mk-II conversions. Good luck with the swap!! -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
| Lo-Fi Version | Time is now: August 20th, 2026 - 10:59 AM |
