Jun 24, 2006 - 12:23 PM
Hey everyone,
For car meets and shows, i'd like to leave my doors open and especially my hatch when I get my new audio system finished this week. But I don't want all my interior lights to be on. Does anyone know of an easy solution for that? I'm wondering if I can just tap into a wire that triggers it all and just hook up a switch. If that can be done, any know where that is? Thanks! -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Jun 24, 2006 - 12:45 PM
Enthusiast ![]() ![]() Joined May 25, '06 From South Carolina Currently Offline Reputation: 3 (100%) |
other day i took off the door panel and i know there is a group of wires that is to that light...but i dunno if u want them ever...but if u never really wanted them, disconnect that wire i would guess...would guess...meaning i not really sure how easy (if it controls somthing else)/pratical it is.
Jun 24, 2006 - 12:50 PM
Enthusiast ![]() ![]() Joined Nov 21, '05 From Wpg, MB. Canada Currently Offline Reputation: 3 (100%) |
Isn't there a switch on the top of the car (where the mid internal light is) that says: on / door / off?
When that's on off, no lights go on when the doors are opened. Haven't checked the trunk tho. |
Jun 24, 2006 - 2:16 PM
i know that works on the main light in cabin, but does that work for door lights?
Jun 25, 2006 - 8:20 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 27, '05 From Texas Currently Offline Reputation: 0 (0%) |
If its a one time even, then i would simply take out the bulbs in the doors, and then turn the switch to off on all the others... As far as the wires go, im not sure.
-------------------- ![]() I am now a part of the ihavemorethen16gc club! |
oops
This post has been edited by JFrost9: Jun 25, 2006 - 8:20 PM -------------------- ![]() I am now a part of the ihavemorethen16gc club! |
Jun 25, 2006 - 8:53 PM
![]() Enthusiast ![]() ![]() ![]() Joined May 5, '05 From New-Brunswick Canada Currently Offline Reputation: 3 (100%) |
pull the "dome" 10A fuse under the hood, that should do the trick for ya
This post has been edited by K-ESD: Jun 25, 2006 - 8:53 PM -------------------- ----------------------6GC's FIRST V6----------------------
![]() JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy |
Jun 27, 2006 - 9:28 AM
QUOTE(K-ESD @ Jun 26, 2006 - 1:53 AM) [snapback]448818[/snapback] pull the "dome" 10A fuse under the hood, that should do the trick for ya will that pull power from the dome light and door lights? -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Jun 27, 2006 - 11:10 AM
QUOTE(Jaws4God @ Jun 27, 2006 - 11:28 AM) [snapback]449464[/snapback] QUOTE(K-ESD @ Jun 26, 2006 - 1:53 AM) [snapback]448818[/snapback] pull the "dome" 10A fuse under the hood, that should do the trick for ya will that pull power from the dome light and door lights? it should, it will disable all interior lights, dash lights, dome, doors, trunk light, etc... -------------------- ----------------------6GC's FIRST V6----------------------
Jun 27, 2006 - 11:24 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 11, '04 From Oakdale, MN Currently Offline Reputation: 3 (100%) |
If you take off the back speaker cover you should see some wires for your door. You can unhook that and then it won't know if the door is open or closed. You can also put I switch there if you really wanted to. The only thing with disconnecting the wires is that your alarm wont work or at least that how it was with mine.
![]() where the crappy arrow is. I don't know but thats what I did. -------------------- -Brad
95 GSX: Stock motor, fp3065, corn = 10.9 @ 140 06 R6: Strappd and sprocketed = 11.0 @ 127 01 a4: daily 94 Celica: totaled - someday have another celica thats fast instead of looks cool |
Jun 28, 2006 - 6:25 AM
Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Hull, UK Currently Offline Reputation: 0 (0%) |
you could switch all the bulbs to led ones mate, they won't hardly draw any current if your concerned about wearing out the battery. I'm about to do that with mine, well on the door markers anyway as other interior lights have switches.
Jun 28, 2006 - 12:12 PM
Enthusiast ![]() Joined Nov 5, '05 Currently Offline Reputation: 0 (0%) |
Just kill the door switch from the one u open,
or keep it pushed in with tape or something. This post has been edited by Conwa: Jun 28, 2006 - 12:15 PM |
Jul 6, 2006 - 1:18 AM
Enthusiast Joined Feb 23, '03 From Toronto, Ont. Canada Currently Offline Reputation: 0 (0%) |
QUOTE(C3L1CA @ Jun 27, 2006 - 9:24 AM) [snapback]449515[/snapback] If you take off the back speaker cover you should see some wires for your door. You can unhook that and then it won't know if the door is open or closed. You can also put I switch there if you really wanted to. The only thing with disconnecting the wires is that your alarm wont work or at least that how it was with mine. ![]() where the crappy arrow is. I don't know but thats what I did. THats what i did it works great |
Jul 8, 2006 - 8:13 AM
QUOTE(K-ESD @ Jun 25, 2006 - 10:53 PM) [snapback]448818[/snapback] pull the "dome" 10A fuse under the hood, that should do the trick for ya why would anyone bother taking the entire interior appart just to disable some of the interior lights for a show? like i said above, pull the 10A "Dome" fuse, thats it. Have a look at what it does http://www.celicatech.com/vfewdsou/1995/95...ic/interior.pdf -------------------- ----------------------6GC's FIRST V6----------------------
Jul 8, 2006 - 11:20 PM
I pulled the fuse and that did what i needed... thank you all!! So much easier than running a switch!
| Lo-Fi Version | Time is now: June 26th, 2026 - 8:42 AM |
