> It's Alive, st205 finally is running!!!!!!!!!&
post Jun 25, 2006 - 5:00 PM
lantz2121
Joined Jun 27, '04
From ohio
After 2 years of resto it finaly is running. I still need to hook up IC pipe vaclines etc. If anyone is knows about the wiring differences for the guages send me a pm. Thanks 6GC.
Replies (1 - 8)
post Jun 25, 2006 - 8:45 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
show us some picts !!
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Jun 26, 2006 - 3:04 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Glad to see you got it working. What do you need to know about the gauges? If you're trying to get the ST205 cluster working in your AT200 this how-to I made will walk you through it:
http://www.6gc.net/forums/index.php?showtopic=30411
If you're just trying to get the stock gauges to work you should already have all the interior plugs charted and it will just be a matter of repinning a few connectors and you'll be all set.
Let me know exactly what you need and I'll try and help you to the best of my ability.
post Jun 26, 2006 - 5:45 PM
lantz2121
Joined Jun 27, '04
From ohio
QUOTE(WannabeGT4 @ Jun 26, 2006 - 8:04 PM) [snapback]449122[/snapback]
Well okay ther is a couple of things; first I want to know how to wire in the fuel pump so I don't have to jump the diagnostic terminals; with the resistor if easily possible or by jumping wires closer to the ecu. Second I am trying to make the st gages work with the st205 harness. The main problem I am having is that all of the wiring diagrams do not seem to have the same wire plug locations lots are not labled. ex some wires are shown by the diagrams I have and some are not. Where there is a wire the diagrams do not show it. Another guy has been helping a little he told me which wires to change to get it started, but i have no tach, fuel level, check engine light, etc. I do not know about speedo, water temp, oil etc. I have only let it run like a min or less. It idols pretty smooth for not having ic piping hooked up and lots of vaccum leaks etc. I need to know what needs re pined at the II-2 II-1 and IJ-1 connectors I think it all has to do with these three plugs. I am not a wiring expert I can repin if I had a list like II-1 to IJ-1 for example. Also there are a lot of wires from the ecu pinout that are left black on the ecu wiring pinout diagram. for example what is?
winj ac1 ats abv rly the eco cco egw els all listed on the circut board of the ecu and have wires to something.
And last what needs changed at the ea1 fusebox plug to make the fans work properly. Thanks lance
post Jun 26, 2006 - 7:21 PM
lantz2121
Joined Jun 27, '04
From ohio
QUOTE(lantz2121 @ Jun 26, 2006 - 10:45 PM) [snapback]449189[/snapback]
75 percent of the problem is taht the 7afe diagrams i have are totally incorrect unless they call the II-2 II-1 and Ij-1 plugs something different. I need complete EWD for the 7afe. I wrote down the differences according to the celicateck bgb for the at200 and st204 and the wires are not there. trying to match functions with that of the st205. thanks lance
post Jun 26, 2006 - 9:45 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
I would love to see it in person.
Maybe August 19th?
- Ryan
aim: rkgreen04
post Jun 28, 2006 - 1:45 PM
scothaniel
Joined May 1, '03
From Michigan
I've found an issue! The 205 diagrams I've been looking at (from Celicatech) list II1 and II2 backwards compared to the 97 EWD I have. So for future clarifications, lets use this for reference:
IJ1 = Dark gray, 3 rows, 17 wires
II1 = Gray, 2 rows, 13 wires
II2 = White, 3 rows, 19 wires
The fuel level sensor goes from the comb meter to the sensor via plug IG1 - this isn't part of the engine harness, so it should work juke like before the swap.
The Tach signal comes from the ignitor through plug II1 - pin 3 (grey wire) - should be the same for both harnesses. Speed sensor wires and water temp sender are also the same.
Be sure to pull out the GR-B wire from II2 - (pin 11 I think) from the engine harness side. This is the boost signal, and you dont have a stock boost gauge.
This post has been edited by scothaniel: Jun 28, 2006 - 1:46 PM
Scott
West Michigan
post Jun 28, 2006 - 1:56 PM
scothaniel
Joined May 1, '03
From Michigan
To run the fuel pump constant, you would run a wire from the circuit opening relay (6 wire relay next attached to the ECU) to IJ1 pin 4 (blue / black wire).
To run the resisitor / relay setup, you have 2 options:
1. Use the ST205 Fuse box, which has the relay and wiring done for you.
2. Use any generic 5 wire relay and the appropriate resistor and wire it manually.
Do you have the fuse block and resistor?
Scott
West Michigan
post Jun 28, 2006 - 6:03 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(scothaniel @ Jun 28, 2006 - 11:56 AM) [snapback]450020[/snapback]
Yup , the fuel pump resistor relay and AWIC water pump relay have their own separate fuse box attached to the radiator on the ST205. It's a few extra wires to run - but if you are starting from the ST205 harness, it should all be there already and just 'work' unless something was modified.
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
Lo-Fi Version Time is now: August 28th, 2026 - 4:03 AM
