> broken harness plug for clock, need serious help
post Jul 7, 2006 - 10:04 PM
chacha
Joined Dec 29, '05
From So-Cal
hey you guys, i have a problem, the heat of the sun melted the black tape that was wrapped around the white adapter in the clock's plug where the ac vent is located and my whole radio system died as well as the clock and the 12v smoke adapter, no more power. When i open the covers to check what was wrong, the wires that connects to the white adapter to the clock's pin was smoking and two of the wires were out...black tape as i have mentioned melted and created a tar like paste inside the adapter....it worries me because this is connected to the other harness inside the car's dash....what should i do? should i cut the wires and reattach it together or just take it to the toyota dealership and have them fix it when i know it will cost an arm and leg? kindasad.gif im soo bummed out..ill try to post some pics so you guys know what i am talking about, but if you know what im referring too....please give me some insights on how to fix it...thanks!
Replies (1 - 12)
post Jul 7, 2006 - 10:13 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
for some reason, i dont think it was the sun that melted the tape. Heat from the sun is not great enough to melt the tape, AND cuase your wires to smoke. I think it was an electrical short that cuased the wires to heat up and smoke and ended up blowing the fuse too becuase the radio system, cigarette lighter, and the clock are all run off the same fuse. My guess is that the 2 wires that were out, were prolly touching, and one just happened to be Positive (+) and the other just happened to be Ground (-). This cuased the electricity to bypass the load (clock) and burn your wires. If you can, repair the wires, by soldering them, or even using connectors, But make sure they are taped up good and dont touch. Solder and shrink wrap is the best choice. Then replace the fuse. Test if your radio and stuff works. If the fuse blows again, then there are more problems, but i think this is the only thing that went wrong.
If the actual connector is broken, just go to a junkyard and go snip snip biggrin.gif .
This post has been edited by MaskedMan: Jul 7, 2006 - 10:16 PM
post Jul 8, 2006 - 1:07 AM
chacha
Joined Dec 29, '05
From So-Cal
Here's the part im talking about...
will it work maskedman? can i find another celica with that part still hanging around...and the fuse, i don't think the fuse is burnt out...i think it's because the wires are not in the adapter anymore, but what do i know....any more comments?
post Jul 8, 2006 - 1:27 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
that looks pretty bad. Some of the wires on the connector are like completely... like not there haha. Ok i recomend going to a junk yard, or something and try to locate that same connector and cut it off with about... 6 inches of wire with it. And then just cut and splice that one onto your car. If you absolutely CANNOT find that connector anywhere at all, here is another option... Try to clean off that white piece. Then take a look to see if that white part is still good, beacuase you may be able to reuse that. And by good, i mean, check to see if it is not melted, and that the "squares" are still separeted from another. If its damaged at all, its better to get a new connector, becuase if the old one is damaged, then the wires may fall out and touch again. If the connector IS good, and you can't find the same connector...then reuse that connector and find any connector with FEMALE pins inside. The same ones that are in that connector. After you find a connector like that off another car, then you can "pick" the wires and pins out of that, and replace them with yours. This way you will have your wire length back so you can cut and splice it in. Make sure the female pins are the same size as yours so they will fit into your connector.
Well it's weird cuase the fuse SHOULD have blown, cuase thats what it's there for. But i guess it wasn't doing it's job, and this is the result. You should prolly check the fuse anyways. The fuse for this is right above the hood release lever, behind the little cover. it's the one that says "CIG RAD". The only reasons that i can think of that the fuse did not blow is either becuase a fuse with a higher of rating was put in that spot instead of whats supposed to be in there, OR there is a wire to wire short that just bypasses the fuse all together.
Sorry if i am not explaining good haha, im like all over the place sorry haha.
This post has been edited by MaskedMan: Jul 8, 2006 - 1:39 AM
post Jul 8, 2006 - 1:32 AM
yo i got that connector and wiring if you want me to cut it off a harness for ya
post Jul 8, 2006 - 1:40 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
QUOTE(playr158 @ Jul 7, 2006 - 11:32 PM) [snapback]453304[/snapback]
oo looks like you wont have to be picking pins afterall biggrin.gif .
post Jul 8, 2006 - 8:23 AM
chacha
Joined Dec 29, '05
From So-Cal
thanks...ill try over the weekend and see if i can do anything to get it back and running...miss hearing the radio and blasting my music...frown.gif Besides..my power window switch for adjusting LEFT & RIGHT button isn't working neither....i hope once i get it fix, it will be okay again and if you can help plyr158 i would greatly appreciate it, i PM you.
This post has been edited by chacha: Jul 8, 2006 - 8:26 AM
post Jul 8, 2006 - 2:45 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
QUOTE(chacha @ Jul 8, 2006 - 6:23 AM) [snapback]453352[/snapback]
wait...so whats wrong with your power window switch?
This post has been edited by MaskedMan: Jul 8, 2006 - 2:46 PM
post Jul 8, 2006 - 4:56 PM
chacha
Joined Dec 29, '05
From So-Cal
its not working either...the left, right, up and down....it's dead with the lights on the roof...that's dead as well...if plyr can send me his extra...maybe it will work if i cut and paste up the new adapter with its wire to the wires inside the dash...
post Jul 8, 2006 - 5:01 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
QUOTE(chacha @ Jul 8, 2006 - 2:56 PM) [snapback]453481[/snapback]
oo your power mirrors. ok ok, well i think those all run off the Fuse marked DOME. but haha this is all of memory cuase i havent seen my car in over a year hmm.. Yeah, well just see what happens when you get the new connector in first. smile.gif
post Jul 8, 2006 - 5:05 PM
chacha
Joined Dec 29, '05
From So-Cal
thanks for the help, i try pming plyr158 but haven't gotten a response.
post Jul 8, 2006 - 5:16 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
no problem. lmk if you have anymore trouble with this. I just completed my electrical training from toyota biggrin.gif
post Jul 9, 2006 - 2:18 AM
chacha
Joined Dec 29, '05
From So-Cal
congrats bro...and thanks for the help, i probably might ask you some in the future... -_^
Lo-Fi Version Time is now: June 26th, 2026 - 6:49 AM
