Jul 23, 2006 - 5:12 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
so apparently i have a short somwhere because if i leave my car sit for more than like 2 days the battery dies.
what are my options here? i usually focus more on the mechanics of a car so when electrical things go wrong im just stupified. thanks guys. |
Jul 27, 2006 - 10:21 AM
![]() Enthusiast ![]() ![]() ![]() Joined May 5, '05 From New-Brunswick Canada Currently Offline Reputation: 3 (100%) |
QUOTE(brianforster @ Jul 23, 2006 - 7:12 AM) [snapback]459740[/snapback] so apparently i have a short somwhere because if i leave my car sit for more than like 2 days the battery dies. what are my options here? i usually focus more on the mechanics of a car so when electrical things go wrong im just stupified. thanks guys. this is the quickest method i can think of take out your multimeter and set it up to mesure current make sure it's not your battery thats faulty by disconnectin the positive and mesuring for current draw if you do detect quite a bit of current then you know it's not your battery. note that there will be a small current draw for things like the ECU memory, clock, radio, etc... after that you have to find out which circuit is drawing current check all aftermarket devices for malfunction then take out a fuse and test the two terminals for current draw, put the fuse back and go to the next (when you do this make sure nothing is on and that you have the door switch pressed in so that the door light circuit isn't on) note all your data on a piece of paper for diagnostic reference get back to us with your findings, good luck -------------------- ----------------------6GC's FIRST V6----------------------
![]() JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy |
| Lo-Fi Version | Time is now: August 26th, 2026 - 9:29 AM |
