Jul 27, 2006 - 2:08 PM
Enthusiast Joined Jul 10, '05 From OTtawa Kansas Currently Offline Reputation: 0 (0%) |
OK i have a 95 celica gT its my baby and i love here to death. i have been leaking oil since i bought it a year ago nothing huge just a little its got alot worse in the last monthe its leaking out of the back of my valve cover onto the exuast and now always smells like its burning. so i heend to know how to get the valve cover of of my celicas 5SFE there are no bolts up top like my hondas so i am cluelesss.
Jul 27, 2006 - 3:46 PM
there are 4 30mm bolts under the spark plug boots.
you may need to remove your throttle cable bracket to get it off. (2 12mm bolts) -------------------- Former Team 5SFTE pro member ;)
Jul 30, 2006 - 2:36 PM
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Jul 30, 2006 - 3:29 PM
Enthusiast ![]() Joined Jun 18, '06 From Aruba Currently Offline Reputation: 0 (0%) |
QUOTE(presure2 @ Jul 27, 2006 - 3:46 PM) [snapback]461948[/snapback] there are 4 30mm bolts under the spark plug boots. you may need to remove your throttle cable bracket to get it off. (2 12mm bolts) careful not to crossthread those 4 large 30mm nuts....AND do not lose any of the cups & seals that are held down by the 4 large nuts. Removing the throttle cable bracket def makes life ALOT easier. I would personally also take a look at the injectors while you have the valve cover off.... -------------------- Toyo'd, Eibach'd, Kayaba'd & BEAMS'd :D
| Lo-Fi Version | Time is now: September 12th, 2026 - 9:45 AM |
