> Members Rides, Can't filter rides
post Jul 27, 2006 - 10:51 PM
CelicaQT
Joined Sep 29, '02
From Sterling Heights, Michigan
I tried every which way to search whether it be "Advanced" search or the regular way and it keeps showing me ALL 1444 members rides.
I tried searching just my SN and same thing all 1444 members rides. Or I've searched, 1997, ST, Auto and same thing 1444 member rides. lol
Amy I not doing this correctly? Been a member for 4 yrs and this is the first time this has happened.
-Christee-
Replies (1 - 9)
post Jul 27, 2006 - 11:22 PM
97lestyousay
Joined Jul 7, '03
QUOTE(CelicaQT @ Jul 27, 2006 - 8:51 PM) [snapback]462209[/snapback]
-Christee-
I just tried it and it worked fine. 14 members for green 97 st hatch? biggrin.gif
JDM guy made me do it.
post Jul 27, 2006 - 11:43 PM
CelicaQT
Joined Sep 29, '02
Ahhh you suck 97lestyousay! biggrin.gif What the heck am I doing wrong? Should I be clearing out my cookie or something?
post Jul 28, 2006 - 12:17 AM
CelicaQT
Joined Sep 29, '02
Ok i just figured out why it's not working for me.
Don't flame, but I did a search and I found a topic on this awhile back.
But basically since I'm a MAC user and I've been using Safari when I do a Members Search it won't work. But in Firefox it's working.
Sorry for this useless post I created.
-Christee-
post Jul 31, 2006 - 6:42 AM
gt4uk
Joined Sep 9, '04
From England
QUOTE(CelicaQT @ Jul 28, 2006 - 6:17 AM) [snapback]462274[/snapback]
-Christee-
yup, thats the problem, i have the same, but i dont mind looking through the list biggrin.gif
post Aug 3, 2006 - 2:45 PM
tomazws
Joined Oct 30, '04
From So Cal
I'm not sure why Coomer used "multipart/form-data" as the form enctype. There is no sort of file uploads, multipart form data might be the cause of the weirdness you encountered. Also, the search form is submitted using GET instead of POST, but that shouldn't be any problem with the browser compatibility. Using GET might even be easier for Coomer to code since all the other pages are also called using GET under index.php. There is no PHP code I could follow therefore I can't really say anything. Though, Coomer did a great job integrating the rest of the website with the Invision board and its database. For example, the "reputation" integration is almost flawless and very very useful for us.
post Aug 3, 2006 - 3:44 PM
tomazws
Joined Oct 30, '04
From So Cal
Confirm problem with multipart encryption and GET method.
Safari doesn't allow GET method for binary form. If it's a binary form, POST method is required. If GET method is required, the form cannot contain any binary data.
Test:
http://www.designrange.com/test/6gc/index.php
Source Code:
CODE
<b>Selected Year:</b><br />
<?php
    if (!empty($_GET["year"])) {
        echo $_GET["year"] . "<br />";
    } else {
        echo "None<br />";
<br />
<form name="form1" action="index.php" method="get" enctype="multipart/form-data">
    <b>Form Eaxmple 1</b><br />
    <br />
    <select name="year">
        <option value="">Please Select a Year</option>
        <option value="1999">1999</option>
        <option value="1998">1998</option>
        <option value="1997">1997</option>
        <option value="1996">1996</option>
        <option value="1995">1995</option>
        <option value="1994">1994</option>
    </select>
    <input name="submit" type="submit" value="Submit" />
</form>
<br />
<form name="form2" action="index.php" method="get">
    <b>Form Example 2</b><br />
    <br />
    </select>
</form>
post Aug 3, 2006 - 7:34 PM
Thanks for that. I use multipart/form-data because I wrapped everything in a form in the basic template (which is a big no-no.) I'll see if I can seperate stuff out soon. And there are file uploads in the manage your account section. wink.gif
Also,
I'm using GET because it makes sharing search results much easier...just copy and paste the URL. Also, it prevents that "the page you are trying to view contains POSTDATA" message if you click on a profile and then go back.
post Aug 4, 2006 - 1:21 PM
tomazws
Joined Oct 30, '04
From So Cal
QUOTE(Coomer @ Aug 3, 2006 - 5:34 PM) [snapback]465104[/snapback]
ah.. very good point.
I don't see any Dreamweaver template markings on your HTML, do you hand code all templates with INCLUDES?
post Aug 4, 2006 - 1:40 PM
QUOTE(tomazws @ Aug 4, 2006 - 11:21 AM) [snapback]465441[/snapback]
I hand code everything, and use some PHP to include whatever files are necessary for the page being requested.
Lo-Fi Version Time is now: September 15th, 2026 - 10:15 AM
