> Check Engine Code 27
post Jul 31, 2006 - 12:57 PM
ShadowPhantom
Joined Oct 19, '05
Do we have two O2 sensors on the 1995 ST 1.8? If their is one after the CAT any suggestions on how to change it? Should I check anything else before buying a sensor? I am at work right now, looking for a quick response.
Thanks,
Chris
Replies (1 - 1)
post Jul 31, 2006 - 9:34 PM
netrata
Joined Feb 16, '06
From Maui, Hawaii
QUOTE(ShadowPhantom @ Jul 31, 2006 - 12:57 PM) [snapback]463605[/snapback]
Thanks,
Chris
I believe your Celica has only 1 o2 sensor which is located on your factory exhaust manifold. But, if your car came with a california emissions standard, then you probably have 2. One being where I already told you and another that is on your exhaust pipe (rear of catalytic converter). Before you buy and 02 sensor, though, try checking the BGB forum on www.celicatech.com and used the repair manuals on there to see what could be wrong with your car.
This post has been edited by netrata: Jul 31, 2006 - 9:36 PM
Lo-Fi Version Time is now: August 11th, 2026 - 9:56 PM
