> Ominous check engine light
post Aug 7, 2006 - 8:50 PM
Vissi
Joined Jun 6, '06
From Cedar Hill ,Texas
For a while off and on i have had the egr 7-1 check light, and it seems to be killing my gas milage. I was just wondering if there is any way to check this out at the house. Iv checked vacume hoses, and iv replaces the vaccume modulator (from the junk yard) and i was jsut wondering what else to do. kindasad.gif
Thanks -dave
0111011001101001011100110111001101101001
Chrome wont get ya home
Replies (1 - 16)
post Aug 7, 2006 - 10:07 PM
check the egr valve itself, pull it off and see if its clogged. if it is try to clean it or replace it.
post Aug 7, 2006 - 10:18 PM
Vissi
Joined Jun 6, '06
How much are they to replace, and were can i get one, jsut in case. Ima pull it off tommorow and clean it out.
post Aug 8, 2006 - 12:19 AM
QUOTE(Vissi @ Aug 7, 2006 - 10:18 PM) [snapback]466576[/snapback]
i dont know how much they cost, but use a pick, carb cleaner or some other nasty strong solvent, and if you can get one...a small stainless brush that can get inside to clean it out. a tiny steel round brush would be good to use, but i dunno where you could get one. i have a couple and i dunno where i got them.
post Aug 8, 2006 - 5:54 PM
toyotatech
Joined Jun 14, '05
From colorado
i would check the vsv too!! i have replaced more of those than anything else.
post Aug 11, 2006 - 2:05 PM
Vissi
Joined Jun 6, '06
vsv? whats that
Anyway there is this black thing on the right of the valve cover (think is my pcv), and it is leakin alot of air through the sides, coud this be hurting my egr system in any way? I havent got around to checking the egr valve just yet though so im not sure if its bad.
This post has been edited by Vissi: Aug 11, 2006 - 3:20 PM
post Aug 11, 2006 - 6:04 PM
puretone
Joined Jun 18, '06
From Aruba
QUOTE(Vissi @ Aug 11, 2006 - 2:05 PM) [snapback]467905[/snapback]
vsv? whats that
heheheheheh get rid of that evil EGR altogether heheheheh
vsv = vacuum sensing valve, this gay little valve that sends a signal to the egr and other things i think....sits right by the cooling-water outlet.
This post has been edited by puretone: Aug 11, 2006 - 6:05 PM
Toyo'd, Eibach'd, Kayaba'd & BEAMS'd :D
post Aug 11, 2006 - 6:21 PM
toyotatech
Joined Jun 14, '05
From colorado
QUOTE(puretone @ Aug 11, 2006 - 6:04 PM) [snapback]467970[/snapback]
vsv? whats that
close its a vacuum switching valve, it opens giving the egr vacuum when the computer decides to turn on egr assuming certain things are happening like proper engine temp, speed, throttle position and so on.it should be under the intake manifold and its a pain to get to. make sure the hoses going to it are ok, and if you want sometime next week i can try to email the diagnosis procedure on it.
post Aug 11, 2006 - 10:02 PM
Vissi
Joined Jun 6, '06
Yea, id love those diagnostic sheets, also would it hurt anything (gas milage,reliability, worse idle than it is,emmisions) if i just removed and caped it.
post Aug 12, 2006 - 7:21 PM
Vissi
Joined Jun 6, '06
Eck, i went and got a new pcv valve and gromet, only problem is that old one was kinda hard, and it broke while taking off, and some of the rubber fell into the valve cover. I wont be able to get to this for a bit, is it gona hurt anything? My idle is alot steader at about 900, i guess thats were it should be cause before it was anywhere from 500-1000.
post Aug 13, 2006 - 2:29 PM
southwest2118
Joined Jan 13, '06
pull your valve cover off and take it out.....it could **** some **** up..depending on how big it was....
vavle cover gasket 15$
some silicone 5$
post Aug 14, 2006 - 6:19 PM
toyotatech
Joined Jun 14, '05
From colorado
whats your email address? i'll try to email that stuff to you in the next couple of day's.
post Aug 14, 2006 - 6:21 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
when i removed my pcv some rubber broke off too and fell inside, i havent had any probs yet.
post Aug 14, 2006 - 6:34 PM
QUOTE(LewFX @ Aug 14, 2006 - 6:21 PM) [snapback]469015[/snapback]
if it clogs an oil galley that outlook make change very very quickly, but not as quickly as the bearing will spin.
post Aug 14, 2006 - 6:52 PM
southwest2118
Joined Jan 13, '06
QUOTE(toyotatech @ Aug 14, 2006 - 6:19 PM) [snapback]469014[/snapback]
who r u talking to?
r u tryin to be funny?
post Aug 14, 2006 - 10:53 PM
Vissi
Joined Jun 6, '06
mines levathan1@yahoo.com
He was talking about diagnostic sheets, as he stated above.
edit: thanks for the input guys, im not to worried, but does anyone know were i can get me a cheap 30mm socket? I checked homedepot and the pawn shop, but the biggest i found was 17mm.
This post has been edited by Vissi: Aug 14, 2006 - 10:55 PM
post Aug 15, 2006 - 12:37 AM
you'll need to look for a place with metric axle nut sockets. try sears or napa
Lo-Fi Version Time is now: September 2nd, 2026 - 5:43 AM
