Aug 8, 2006 - 4:54 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 30, '06 From Augusta, GA Currently Offline Reputation: 4 (100%) |
Has anyone had any repeat issues with a head gasket leak? I was told by Toyota today that it's leaking, but I know I replaced it roughly 6 months ago! Any thoughts? Thanks in advance.
-------------------- 2007 Subaru Impreza WRX STi 1974 Datsun 260Z 1997 Subaru Legacy L Wagon Kind of missin' my Celica GT! Hit me up if you're ever in my area. I'm always down for a meet. |
Aug 11, 2006 - 6:32 AM
Enthusiast Joined Apr 23, '06 From Cape Town South Africa Currently Offline Reputation: 0 (0%) |
first off did your car run hot?
there can be a couple of reasons, either your head or block is warped your headbolts can be stretched, i always use a copper gasket sealer to seal my gaskets. |
Aug 11, 2006 - 6:43 AM
when you replaced it the first time, did you check the head and or block for warpage?
who did the work? -------------------- Former Team 5SFTE pro member ;)
Aug 11, 2006 - 7:21 AM
QUOTE(presure2 @ Aug 11, 2006 - 6:43 AM) [snapback]467783[/snapback] when you replaced it the first time, did you check the head and or block for warpage? who did the work? no i didn't check, but i just had a shop swap the engine. what kind of signs should i look for? -------------------- 2007 Subaru Impreza WRX STi 1974 Datsun 260Z 1997 Subaru Legacy L Wagon Kind of missin' my Celica GT! Hit me up if you're ever in my area. I'm always down for a meet. |
Aug 11, 2006 - 7:31 AM
well, you need to make sure the 2 surfaces are truly flat, and smooth for the gasket to seal properly.
Aug 11, 2006 - 7:50 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
What is the actual problem?
Are they saying it's leaking in the cylinders or outside? -------------------- ![]() |
| Lo-Fi Version | Time is now: August 29th, 2026 - 9:45 PM |
