> Headlight Changing
post Aug 13, 2006 - 2:02 PM
Craig14Nielsen
Joined Aug 13, '06
From Lansing
im having trouble changing my drivers side headlight bulb ive removed the bolts i can see but it still seems to be attacthed at the bottom, i was wondering anyone else has had this promblem
Replies (1 - 4)
post Aug 13, 2006 - 2:06 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
you dont have to take out any bolts for the bulb, just twist and pull out
post Aug 13, 2006 - 2:18 PM
bloodrain
Joined Mar 3, '05
From Hollywood, FL
If your change the actual headlight, you need to remove the bumper, which has about 25 bolts. If your changing the bulb all you do is twist it and pull it out, simple.
Oh btw there are 3 bolts that hold the headlight down.
This post has been edited by bloodrain: Aug 13, 2006 - 2:18 PM
To live, is to suffer
post Aug 13, 2006 - 2:55 PM
Craig14Nielsen
Joined Aug 13, '06
From Lansing
the trouble im having is getting to the bulb
post Aug 13, 2006 - 3:16 PM
massbrandon
Joined Mar 6, '06
From massachusetts
QUOTE(Craig14Nielsen @ Aug 13, 2006 - 3:55 PM) [snapback]468559[/snapback]
just look at the back side of the headlight. grab the little plastic piece that holds the bulb and twist and pull. the should be it.
Lo-Fi Version Time is now: August 11th, 2026 - 11:55 PM
