Aug 20, 2006 - 11:29 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) |
After fueling, lift the hose with the handle still depressed to
get the gas in the hose below filler cap. Actually a person could get a dollar in gas and almost another dollar free. Unless the person in front of you has drained the hose as well. -------------------- JDM guy made me do it.
Aug 20, 2006 - 12:11 PM
![]() Enthusiast ![]() ![]() Joined Jul 28, '06 From Moncton, New Brunswick Currently Offline Reputation: 0 (0%) |
Good tip! I'l try it when I get home and get to drive again
**** thats gonna feel good to be able to drive again. -------------------- ![]() |
Aug 20, 2006 - 12:18 PM
Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Hull, UK Currently Offline Reputation: 0 (0%) |
QUOTE(97lestyousay @ Aug 20, 2006 - 5:29 PM) [snapback]470837[/snapback] lift the hose with the handle still depressed I know you mean just emptying the pipe out from the pump to the nozzle but surely if you keep the handle pressed it will just keep pumping petrol? Oh and I did this once and it added money onto the pump so I haven't done it since. maybe your pumps are different to ours though. |
Aug 20, 2006 - 12:22 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 9, '05 From Long Beach Currently Offline Reputation: 1 (100%) |
hehehe sticky! lol ima try it, how do u kno if sum gass goes in?
-------------------- Is this good enuff 4 ya? :D
Aug 20, 2006 - 12:46 PM
QUOTE(vsideboy @ Aug 20, 2006 - 10:18 AM) [snapback]470847[/snapback] QUOTE(97lestyousay @ Aug 20, 2006 - 5:29 PM) [snapback]470837[/snapback] lift the hose with the handle still depressed I know you mean just emptying the pipe out from the pump to the nozzle but surely if you keep the handle pressed it will just keep pumping petrol? Oh and I did this once and it added money onto the pump so I haven't done it since. maybe your pumps are different to ours though. It only works on pumps with a lever type switch. ( lift handle type) when finished shut off switch at pump- re-depress nozzle handle, gas in line will continue to flow from shut off valve to nozzle. loop in hose has more. You are kind of ripping off the next guy to use the pump, but who is to say the guy before you didn't do the same thing. -------------------- JDM guy made me do it.
Aug 20, 2006 - 1:14 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 18, '04 From Portland OR / Vancouver WA Currently Offline Reputation: 0 (0%) |
Hmmm. If thats true then im just gonna hit up every nozzle at the gas stations lol
Aug 20, 2006 - 3:24 PM
![]() Enthusiast ![]() ![]() Joined Jul 6, '03 From Long Beach, CA..."LBC" Currently Offline Reputation: 0 (0%) |
yup it works...been doin that since gas was 99 cents a gallon
Aug 20, 2006 - 3:50 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 25, '03 From Miami, FL Currently Offline Reputation: 9 (100%) |
i dont get it... can someone please videotape this technique?
Aug 20, 2006 - 8:53 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Hollywood, FL Currently Offline Reputation: 0 (0%) |
if i understand this correctly when the hose is in a U shape, u lift the bottom of the hose up and 'flush' out the extra gas.
-------------------- To live, is to suffer
To survive, thats to find meaning, in the suffering.... ![]() |
Aug 20, 2006 - 9:16 PM
i get it. the pump should have an on/off switch. so after pumping to the desired amount, you shut off the switch at the pump. then depress the handle and lift the hose to get the remaining gas inside the hose.
Aug 20, 2006 - 10:58 PM
i tried it today and i think i got it... but i didnt lift the hose... because the pump i go to doesnt stop chargin money till you put it back in its holding thing. so i put it back and then back into my gas tank and pulled the handle... not sure if that workeD?
Aug 21, 2006 - 4:16 AM
QUOTE(amysmojo @ Aug 20, 2006 - 7:14 PM) [snapback]470862[/snapback] Hmmm. If thats true then im just gonna hit up every nozzle at the gas stations lol haha, yeah just stop off at all the stations in town and just empty all the pipes into your tank, end up with a full tank for nothing haha. |
Aug 21, 2006 - 8:58 PM
is any of this illegal at all? i dont wanna go to jail again. lol...
Aug 21, 2006 - 9:05 PM
^^^ I wouldn't go around draining every hose in town,
the Idea is to get the rest of the gas out of the hose you used to pump after paying. I'm not sure how it could be illegal if you aren't pumping and driving away without paying. Possably immoral.lol -------------------- JDM guy made me do it.
Aug 22, 2006 - 12:30 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
dont think it would work, like if you push the handel the pump goes, like are you trying to say, once is auto clicks off push it again and with it auto shut off lift the handel and let the excess drip down, only issue is that when you tilt it up your gana let fresh air in and the auto stop is gana release starting the pump again.
I think i'ts very pump spacific or i'm not understanding it right. is it worth it though? like legaly there is nothing wrong with shanking the last bit but like if its already gone though the pump you already payed for it, or are you saying, before you even put money on the pump clear the lines with what the other guy in front of you payed for, (nothing bad about taking what the other guy left ya -------------------- ![]() |
Aug 23, 2006 - 3:14 AM
hehe i think it worked. i put 5 dollars and well i duno it got me almost 40 miles street.
maybe it works... maybe it dosent work... lol ima check again next time i get an empty tank. -------------------- Is this good enuff 4 ya? :D
| Lo-Fi Version | Time is now: May 26th, 2026 - 12:27 AM |
