Aug 30, 2006 - 5:44 PM
So, i decided to go on a road trip yesterday/today. I drove from my house to Ottawa. Its about 1000KM back and forth. So I know my headers usually give off some heat, but wow! After about 5 and a half hours of driving, every thing under my hood was stupidly hot, and also my re-located cat was so hot that it was almost impossible to touch the center console. So, i already wrapped part of my headers, but not all of them as of yet, about 80% is wrapped. So after this, my engine bay is so hot that i cant even open my hood now (even though ive been home for 40 min and the cars been sitting). The car otherwise is running nice and cool. Temp gauge is below middel, oil is fine, just every thing else is stupidly hot. So, ive got 2 days b4 i move down to school. So i have to wrap up the rest of the header, my down pipe and my cat just to help keep the heat in. Any one else who has headers have a problem with ecessive heat??
Aug 31, 2006 - 6:06 AM
Enthusiast ![]() Joined Jul 20, '04 From Russia, Moscow Currently Offline Reputation: 0 (0%) |
Wrapping the cat is not a good idea since it's not designed to hadle such high temps. Having a cat and using heat wrap on your header is a bad idea in the first place.
Aug 31, 2006 - 7:13 AM
if its a thinwall stainless header then wrap isnt bad for the cat, that thinwall stainless lets out alot of heat which isnt so great.
however your stuff shouldnt be getting that hot, if your cat is radiating out that much heat i would think that you're running rich and burning up your cat. with extended driving my unwrapped header would get the hood hot, but no hotter than sitting in the hot sun all day. i think this excessive heat could be an indication that your engine isnt running right. -------------------- |
Aug 31, 2006 - 9:43 AM
Enthusiast ![]() ![]() Joined Aug 18, '04 From Silverdale, WA Currently Offline Reputation: 0 (0%) |
QUOTE(Bitter @ Aug 31, 2006 - 5:13 AM) [snapback]474795[/snapback] if its a thinwall stainless header then wrap isnt bad for the cat, that thinwall stainless lets out alot of heat which isnt so great. however your stuff shouldnt be getting that hot, if your cat is radiating out that much heat i would think that you're running rich and burning up your cat. with extended driving my unwrapped header would get the hood hot, but no hotter than sitting in the hot sun all day. i think this excessive heat could be an indication that your engine isnt running right. I agree. My wife had an 84 accord and it seemed to run fine but the cat would be smoking after jus 30 minutes of driving. come to find out it was clogged from the engine running rich. You might want to check it out. Also wrapping anything under the car won't last long. If the wrap gets wet it will loosen and come apart. If you find that there are no issues with the engine or the cat then just look into getting some heat shielding in that area. |
Sep 4, 2006 - 1:44 PM
QUOTE(Bitter @ Aug 31, 2006 - 7:13 AM) [snapback]474795[/snapback] if its a thinwall stainless header then wrap isnt bad for the cat, that thinwall stainless lets out alot of heat which isnt so great. however your stuff shouldnt be getting that hot, if your cat is radiating out that much heat i would think that you're running rich and burning up your cat. with extended driving my unwrapped header would get the hood hot, but no hotter than sitting in the hot sun all day. i think this excessive heat could be an indication that your engine isnt running right. When i head home next im gonna get my buddy to check it out. QUOTE(bindertch @ Aug 31, 2006 - 9:43 AM) [snapback]474822[/snapback] QUOTE(Bitter @ Aug 31, 2006 - 5:13 AM) [snapback]474795[/snapback] if its a thinwall stainless header then wrap isnt bad for the cat, that thinwall stainless lets out alot of heat which isnt so great. however your stuff shouldnt be getting that hot, if your cat is radiating out that much heat i would think that you're running rich and burning up your cat. with extended driving my unwrapped header would get the hood hot, but no hotter than sitting in the hot sun all day. i think this excessive heat could be an indication that your engine isnt running right. I agree. My wife had an 84 accord and it seemed to run fine but the cat would be smoking after jus 30 minutes of driving. come to find out it was clogged from the engine running rich. You might want to check it out. Also wrapping anything under the car won't last long. If the wrap gets wet it will loosen and come apart. If you find that there are no issues with the engine or the cat then just look into getting some heat shielding in that area. The heatsheilding/wrap that im using is the DEI wrap, its a fiberglass wrap, it doesnt decompose, retains heat quite a bit. My friend who has an RB25 in his S13 wrapped his turbo manifold, down pipe, and full exhaust wrapped in it. He runs his car all parts of the year and hes had it on there for 2 years or so. Only problem he has had is he bottomed out a on point and ripped the wrap in a small section where the piping goes under his axel. I havent had any problems with head untill i put my headers on. |
| Lo-Fi Version | Time is now: September 1st, 2026 - 1:46 PM |
