> Low Boost, Low Octane, Full tank of 87 octane
post Oct 3, 2006 - 3:04 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
The swap's almost done and I've got a tank full of 87 octane. What is everyones opinion on running just 6-7psi with the T-VSV capped off.
Replies (1 - 8)
post Oct 3, 2006 - 3:08 PM
shin
Joined Aug 21, '04
From New York City
shouldn't you run like 93oct if ya boosted?
~*MuH NeW RiDe*~
post Oct 3, 2006 - 3:20 PM
87 is too low for a boosted car kindasad.gif risking detonation isn't fun....
post Oct 3, 2006 - 3:23 PM
how much is in there?
you can drive it carefully to use up the gas, but do NOT boost at all.
post Oct 3, 2006 - 3:36 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
You know what guys nevermind... This is an RC ECU so I think I'm going to be on the safe side and just drain it... unless you guys think adding a 1/4 tank of 110 octane would do the trick.
post Oct 3, 2006 - 3:45 PM
Predator
Joined Feb 26, '05
From Sweden
better safe than sorry
post Oct 3, 2006 - 4:12 PM
jgreening
Joined Jan 17, '04
From Illinois
Of course you can use it. The ECU will compensate for any octane induced knock you get and retard timing. Its not a big deal. Just dont boost hard. Its probably what you want to do anyway for the first several miles. Also, if you have a good intercooler, you might not even get knock response.
BTW, did you actually get the AT working with the 3S?
post Oct 3, 2006 - 4:52 PM
QUOTE(WannabeGT4 @ Oct 3, 2006 - 4:36 PM) [snapback]486963[/snapback]
dont try to drain it. just drive the car normally. like greening said, the ecu will compensate for it. you probably have a new clutch in there, so you can ride it out, boost free while the clutch breaks in. just dont do any WOT runs.
post Oct 3, 2006 - 6:33 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
I'll just be careful I guess.
As for your question Jay, You'll have to stick around and find out.
Lo-Fi Version Time is now: May 16th, 2026 - 11:18 AM
