Oct 10, 2006 - 11:48 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) |
As some may know i am just about finished with my 3s swap (knock on wood) and soon I'm going to put on a custom 3 in exhaust, keeping the stock DP for now..
flex pipe and tubing 6 inch flex pipe or 8? also should all of my tubing be stainless or will it not matter if i get aluminzed steel? (i dont care so much about show, but i dont want it to rust out in a week...) ^any ideas about that stuff? what mandrel bends do i need? and how much straight pipe do i need? Resonator Magnaflow Resanator cat MagnaFlow HF Metallic Spun Converter - 59959 (will buy it soon) muffler Magnaflow Race Series 14835 Ok so i found what converter and muffler im getting, but i still need a bit of guidance on what to do for the rest... This post has been edited by jcbass7: Oct 18, 2006 - 9:11 AM |
Oct 10, 2006 - 12:29 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Run the stock DP for now until you can afford a good one. I run 3" all the way back no cat, no resonator and just a muffler. Not sure what my flex pipe is though.
Oct 10, 2006 - 12:35 PM
is the stock dp 3in? will this matter any?
i was just going to snag a flex pipe from ebay or something like that.. but wasn't sure if i should do everything in stainless or aluminized steel Mandrel SS Tubing Stainless Tubing SS 3x8 Flex Pipe I was thinking of something along those lines^? This post has been edited by jcbass7: Oct 10, 2006 - 12:40 PM |
Oct 11, 2006 - 7:05 AM
Enthusiast Joined Oct 6, '06 From UK Currently Offline Reputation: 0 (0%) |
QUOTE(jcbass7 @ Oct 10, 2006 - 12:35 PM) [snapback]489930[/snapback] is the stock dp 3in? will this matter any? 3S-GTE is 2.5" OEM/Stock If you’re running a CT20b you will get major boost creep running a full 3" system, unless you get the dual wastegate port machined out to one port. |
Oct 11, 2006 - 5:22 PM
QUOTE(JDM_ST205_WRC @ Oct 11, 2006 - 7:05 AM) [snapback]490234[/snapback] QUOTE(jcbass7 @ Oct 10, 2006 - 12:35 PM) [snapback]489930[/snapback] is the stock dp 3in? will this matter any? 3S-GTE is 2.5" OEM/Stock If you’re running a CT20b you will get major boost creep running a full 3" system, unless you get the dual wastegate port machined out to one port. I'm rocking the stock CT-26 |
Oct 17, 2006 - 9:09 AM
well i bought the muffler,
I got a Magnaflow race series 14835 Next up is the cat, any good high flow cats out there? |
Oct 17, 2006 - 10:00 AM
check www.horsepowerfreaks.com they have a good selection of high flow cat. make sure you get a metalic on NOT ceramic.
Oct 17, 2006 - 1:53 PM
QUOTE(Culpable04 @ Oct 17, 2006 - 10:00 AM) [snapback]492647[/snapback] check www.horsepowerfreaks.com they have a good selection of high flow cat. make sure you get a metalic on NOT ceramic. That site has some good stuff.. I decided on this: MagnaFlow HF Metallic Spun Converter - 59959 any ideas about a resonator? |
Oct 17, 2006 - 2:33 PM
^^ I think they have the same catalitic with some kind of built in resonator. I'm not sure.
Oct 18, 2006 - 9:12 AM
ok i have most of it figured out, all i need still is the piping, flex pipe and mandral bends.. what should i order?
| Lo-Fi Version | Time is now: July 29th, 2026 - 2:27 AM |
