> HKS 'Circle Earth' Grounding Kit, thinking about fitting one
post Oct 27, 2006 - 6:02 AM
gt4uk
Joined Sep 9, '04
From England
anyone got one of these fitted?
HKS Grounding Kit
i have heard they are good for reducing fuel consumption, by improving spark...etc..etc..
anyone?
adrian
Replies (1 - 16)
post Oct 27, 2006 - 7:38 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
Honestly? Just take about 3 meters of normal 8mm wire that you use to run the power for your audio system - take good gold plated end links for the wire - make a good earth point in your engine bay - and run all your wires from there to the earth points on your engine - it will be 10x cheaper - and it will perform the same. Ofcorse it wount be HKS...
<<<<<< DCw / JDMart >>>>>>>
post Oct 27, 2006 - 7:45 AM
gt4uk
Joined Sep 9, '04
From England
QUOTE(doGGy @ Oct 27, 2006 - 1:38 PM) [snapback]496721[/snapback]
are they worth it though? ignorning the name..etc, is a good grounding kit worth the time/money..etc
post Oct 27, 2006 - 10:53 AM
doGGy
Joined Oct 28, '02
QUOTE(gt4uk @ Oct 27, 2006 - 5:45 AM) [snapback]496724[/snapback]
If you mean HKS ones and other - for the Brand name - you will pay the Bran Name price - but they will perform the same way as the all other cheap or made by your self wires... It give the same grounding effect - what ever you do - it MIGHT be better if they there made from Silver wires or somthing biggrin.gif
But really - putting this Grounding kit - you wount feel much of the differnece. But if you check the stock Groundd wires in your Engine bay - you will see that they are really tiny ones, and time has took his effect on them already and Cooper is already started rusting inside. Get some cheapo kit from Ebay and try it out. But as i suggested - instead of this - get some good battery clamps, one for ground and one for Power (Ussualy i used these then i was installing Car audio, so check car audio shops) these clamps have place for the 5 wires to go in them, put one on the battery ground terminal, run the 1 wire from it to the good ground on chasis, and then run all the other wires to the ground points - if you do all this clean and profesionally - it will look good, and will perform the same way as the other High brand stuff...
post Oct 27, 2006 - 10:56 AM
shin
Joined Aug 21, '04
From New York City
honestly.. there's not much of a difference.. defgeph hated it lol. but yea.. i have one of those ebay grounding kit and it's there just for looks... don't feel anything.. honda guys however said there's a significant improvement but that's them laugh.gif
~*MuH NeW RiDe*~
post Oct 27, 2006 - 4:41 PM
soven
Joined Mar 14, '05
From Auckland,New Zealand
Copper is copper. Much cheaper to buy your own wire.
Grounding kit should help with the car's electrics since our factory ones are pathetic. Doubt you will notice a big difference though unless you are running an audio setup and the factory one isn't sufficient, causing dimming lights etc.
post Oct 27, 2006 - 5:04 PM
JDM_ST205_WRC
Joined Oct 6, '06
From UK
Big +1 to that, I've done a dyno with the wires on & without them, all but 2 BHP @ the fly difference between the 2 of them mad.gif
I've also got a "magic" box of tricks to go with the wires... does fu@k all, makes the car slower by adding weight if anything rolleyes.gif mad.gif
It's a fu@kin rip off & they should be brought to court for miss advertising if anything! mad.gif
These fu@kin main stream companies think we will buy any old sh1t they sell just because they put their name on it… mad.gif rolleyes.gif
Fu@kin over priced wank product pushers! & HKS are the worst of them all! mad.gif rolleyes.gif
This post has been edited by JDM_ST205_WRC: Oct 27, 2006 - 5:05 PM
post Oct 30, 2006 - 6:32 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
QUOTE(JDM_ST205_WRC @ Oct 27, 2006 - 6:04 PM) [snapback]496882[/snapback]
I agree with you tho
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Nov 3, 2006 - 10:16 AM
Jaws4God
Joined Mar 27, '04
So does a ground kit help with audio (dimming lights)? I noticed mine is still dimming the lights on a few songs even with my cap... so wanted to see if I can use some wires i have already to ground everything better..
post Nov 3, 2006 - 12:14 PM
hitcachi
Joined Jun 19, '05
From Nebraska
QUOTE(Jaws4God @ Nov 3, 2006 - 10:16 AM) [snapback]499079[/snapback]
It certainly wouldnt hurt. Just remember one thing when you upgrade ground wires. Electrical currents dont care about brand names.
post Nov 3, 2006 - 12:23 PM
Jaws4God
Joined Mar 27, '04
QUOTE(hitcachi @ Nov 3, 2006 - 5:14 PM) [snapback]499108[/snapback]
right.. i have a bunch of free wires laying around...
just need to know what size to use and where the best ground points are...
post Nov 4, 2006 - 3:28 AM
soven
Joined Mar 14, '05
Best grounding points are any part of the car chassis. Make sure to sand off the paint and after bolting the lug down, spray some paint over it or use nail polish etc in order to stop it from rusting. What I will upgrade first is the battery ground in the engine bay. The factory one is pathetic. Use 8gauge at least. I used 0gauge for mine.4 gauge would be reasonable and would not cost much. Should solve the headlight dimming issue.
Next I would do is make sure the amps are grounded properly as well. The place where the middle hinge for the rear seats bolt to ,works fine for me.
post Nov 4, 2006 - 11:26 AM
hitcachi
Joined Jun 19, '05
From Nebraska
QUOTE(Jaws4God @ Nov 3, 2006 - 12:23 PM) [snapback]499112[/snapback]
lol, sorry Jaws, 2 gauge or 4 gauge would definitly be fine and you can just ground to one of the factory grounds or make your own anywhere on the chassis, as long as its a good end connector holding it down.
post Nov 14, 2006 - 3:33 PM
celiracer
Joined Oct 5, '05
From NE
I also have done this. I bought my own cost me about $20 it helps from dimming when you have a system. But i just did it because it just makes it look better.
post Nov 14, 2006 - 4:32 PM
hitcachi
Joined Jun 19, '05
From Nebraska
This post has been edited by hitcachi: Nov 14, 2006 - 4:35 PM
post Nov 14, 2006 - 4:36 PM
celiracer
Joined Oct 5, '05
From NE
QUOTE(hitcachi @ Nov 14, 2006 - 4:32 PM) [snapback]502298[/snapback]
Yea i paid Aaron to buy the parts, and he helped install them.
post Nov 14, 2006 - 4:40 PM
hitcachi
Joined Jun 19, '05
From Nebraska
Lo-Fi Version Time is now: August 23rd, 2026 - 6:31 PM
